At the Track!!
At the Track!!
Alright, Im about to take my car to the track for the first time. I dont wanna be embarrased either, so someone give me the 411 on how it will take place. I understand the burnout pit, i got that part down. then you move up to the line. How do you launch, is mainly what I want to know. I dont wanna end up spinning my tires at the starting line like a DA. Let me know! I have an auto!
Roll a little ways past the water box, hold down brake while giving throttle to do burnout, burn for about 5-8 sec until nice and smokey,roll forward to first staging bulb, then light up the second bulb. Hold brake while raising the rpms with the trottle to desired launch range(flashing the converter), then leave on last yellow light(when you see it light up, let off brake and hit the trottle). Maintain WOT until end of track, swing by the timeslip booth and get ticket...repeat as needed.
Like the guy above said when you second set of staging bulbs come on bring the rpms up a little bit. If you have a stock stall converter expect not to leave at 3k rpms, you'll just be sitting there doing a line lock. I had a 95z28 with factory stall converter and I couldn't leave much above I'd say around 1500-1800, maybe that's even pushing it, it was quite some time ago and that was the first car I ever took to the track. But anyways I brang the rpm's up the best I could and could feel the tires starting to break loose ever so slightly. But don't worry, after you get the hang of it and the feel for the car it will be a breeze. It's kinda nerve wracking your first time cuz everyone is watching but all goes away after the first time down the track. It won't even bother you the second time around.
Oh...btw, turn off TC if you have it. My 2000 TA didn't , so I didn't have to worry about it. The vette has it, but I run with it off and AH on. AH only kicks in if you're 11/10ths sideways.
Administrator
Just do a light burnout to clean the tires off. Heating up street radials
tends to make them greasy, not sticky.
I agree with everything else.
Better yet, drive around the water box. Don't go through it...period...assuming you're on street radials. You'll screw up traction for everyone else because you'll be leaving water all over the place.
Administrator
Here was my technique in my 2000 A4 Z28. Keep in mind that I was
running street radials (Kumho Ecsta 712's) on stock 16" wheels:
1.8 60' on street tires:
Again, whatever that technique is...don't leave water on the line for
those of us running big tires.
Best of luck.
- Drive around the water box.
- Back up enough to create some room (don't back into the water box).
- Do a light burnout for 2 seconds or so just to clean the tires off.
- Light the first bulb.
- Let your opponent stage.
- Light the 2nd bulb...but just barely light it up.
- Keep your left foot on the brake.
- Keep your right foot on the gas pedal.
- Bring the rpm's up and flash the converter a bit (~1500rpm).
- On the 3rd yellow (sportsman tree) roll into the throttle aggressively.
- You should be at WOT by the time you count "one one-thousand".
- Keep the gas to the wood past the finish line (don't let out early).
- MTI lid
- Hooker Catback
- Free mods (TB bump stop mod, !FRA)
- Nitrous
Best of luck.
I agree...thats one part I forgot, but it's also one piece of advice I didn't get until about my 3rd or 4th year racing.It helps improve 60ft, kind of a small"running start" and saves you from redlighting . Good input!
1 Post
Best of luck.
- MTI lid
- Hooker Catback
- Nitrous
Best of luck.
wow 11.5 with only those mods???? u dident have a stall or something!! how much shot of nitrous?? that is a real good time
Administrator
Yes sir.
Nope...stock converter.
Oh...not too much...just a little old NX wet kit.
Thanks. It was a real sleeper that's for sure...stock 4x4 ride height
and everything. I beat that car hard and she just kept begging
for more. Gotta love LS1's.
1 Post
wow thats very ******* amazing!!! almost hard to believe!! at the track i ran 14.5 at 103 with most of my mods, but i got a really bad 60! it was lik 2.8 mines even an M6, but wow that time really surprised me, i wish u could take my car down the track
Administrator
111mph but I don't believe it since I never backed it up. I never did catch
a good short time N/A. It had a 12.85 in it for sure.
Keep in mind that my car was had a 4L60E (easier to drive) and it was
a Z28 with few options. It wasn't a stripper car, but it was pretty light
all things considered.
Good luck dude. My first time out I ran a 14 something on street tires spinning for about 3 seconds. My best pass of the night was a 12.5 and I was still spinning. I went around the waterbox and slightly put the rears in and burned out after. You will get the hang of it and after doing it once you won't want to stop.
1 Post
In naturally aspirated trim, it went 13.0 @ 107mph on a 2.0 60'...once trapped
your trap is really good for running 13 flat, yea for the A4 the most important is the launch, i was still using the stock shifter, so my shifting was not so great at all! but 12.8 is alot better then i would expect from your car. your numbers are very impresive to me, im still amazed!
Administrator
after a while.
