07 LS2 Intake Manifold
Old 02-16-2008, 01:59 PM
lq9dime's Avatar
Default 07 LS2 Intake Manifold
Will a 07 LS2 Intake manifold bolt right up to a 02 6.0 lq9 block?
Old 02-16-2008, 02:24 PM
2manycars's Avatar
It will bolt right up to the heads but you will need to use the LS2 rails and probably injectors too. My question is what are you puting this engine in because if you have the hood clearance the LQ9 makes great power and gives you a bit of a sleeper look.
Old 02-16-2008, 02:26 PM
lq9dime's Avatar
I am doing a swap in an s10 pickup.
Old 02-16-2008, 02:41 PM
2manycars's Avatar
Sweet! I want to put a 5.3 w/ a 100 shot in my 90 eventually. What is it 2x, 4x, auto, stick, year, cab?
Old 02-16-2008, 03:15 PM
lq9dime's Avatar
01, 2wd, auto, ext cab.
Can you recommend a good throttle body for the ls2 intake?
Old 02-16-2008, 05:09 PM
2manycars's Avatar
Yea the LS2 opening is 90mm from the factory but electronic. So your gonna need a throttle linkage bracket as well. From what I hear the Holley 90mm comes with a bracket but for my money I would try to get a used 90mm TB off this website or ebay and you can pick up the bracket new. I think SLP sells the bracket by itself but if not just start clicking on the advertisers and your sure to find one.
Are you using your factory tranny?
Old 02-16-2008, 05:14 PM
lq9dime's Avatar
So you can convert a drive by wire to throttle linkage?
No I am running a 4L60e, I got corvette servos, clutch packs, and shift kit for it.
Old 02-16-2008, 05:31 PM
2manycars's Avatar
Yes, I'm guesssing your running the LQ harness and Computer? If that were the case you wouldn't have a way to control an ETC anyway.
Old 02-16-2008, 06:10 PM
lq9dime's Avatar
My buddy is actually making me a custom harness, but yeah I dont want etc anyway. Well thats cool, if you see a deal on a 90 mm let me know.
