Rear tires only
Rear tires only
Any problems with just purchasing 2 rear tires at a time instead of all four? Not had the car for very long and was wondering if only a rear tire(s) purchase would affect anything?
Yes. Both rears at the same time. All 4 tires have been rotated at 4000 mile intervals. Just wanting more grip from the rear and not wanting to spend the $$$$ for all four new tires.
X2 no 315's. The factory wheels are not wide enough. Dont go bigger then a 275 on those. If you want a street tire look at the Goodyear eagle GSD3's there great. If you want a drag radial. Look at either BFG drag radials if you want rock solid performance and dont drive it in ran. If you want an inbetween tire go with Nitto Drag radials, there decent in the rain for a drag radial.
I have had great results with the G-force line of BFG's for DD. they last a good amount of time and hook pretty good.
Nitto drag radials will wear out pretty fast. so if money is a issue i would stay away.
When it came time fo me to replace tires, I could only afford two at a time, I found that the rears were a lot more worn out than the front ones though so they got bought first and I went with a set of Nittos cause they were so awesome back then.
I went with firehawk wide ovals made by firestone, when i swiched to torq thrust rims 17/9 for the front and 17/11 rear. 275 up front and 285s in the back. they seem to have excelent dry traction but i havent done any diriving in the snow or rain so i dont know about that. they are a directional tire that has kinda mean look to them
Thanks for the help so far! Any other advice on a good all season tire (since this is my DD) would be appreciated. Tread life and handling on these Sumis stinks.
Moderator
Car will handle the best with all 4 tires the same and the same wear. But there is no problem replacing only 2. A lot of people change just the rear for drag radials. Depends on what you want out of the car.
Corner carving, replace all the same. Drag race, front for less wieght (skinnies) Rear for traction. Street somewhere in between.
