Push Starting LS1 Safe?
Is it safe for an LS1 to be exessively push started? By push start, I mean having the car rolling and then engaging the clutch.
I was advised to do this as much as possible to avoid unnecessary use of the starter motor, but I just want to make sure this won't cause any unusual strain for a 4th generation TA.
I wouldn't do it a lot. I've only done it once when I had to. I'm not sure what exactly can go wrong, but it's definitely not worth it for the life of the starter. do you mean you start your car all the time like that?
Ya that is kinda strange is the starter going bad? its always better to use the key and if it was bad for the starter to use the key then there would be a lot of broke down a4 cars. Also bump starting should only be done when needed.
^^ agreed. its more wear on your clutch most of all. i would rather spend $100 on a starter than $350 on a clutch.
i wouldnt listen to anything from whoever told you that.
((((((Administrator))))))
I have done it a BUNCH on one of the previous cars i owned, but not becuase of choice but because my starter was a piece. Im with these guys, push starting your car does not justify wear on the starter or the price of a new one if you ever have to buy one.
who the hell told you to do that??? honestly thats the worst advice ever, think about the drivtrain probs later on.... labor alone to drop/clutch the t56/4l60 would be 10x the cost of starter...
im glad you asked us befor trying this...
Well, I'm definitely glad I asked about it first. It was actually my father who recommended this. He said he used to do this all the time with his manuals, such as the V6 Maverik, which was the last manual he owned. Myself, I'm accustomed to automatics for the most part, and of course, you can't do this with auto even if you wanted to. I specifically asked him if push-starting causes any extra strain/wear on the engine or drivetrain, and he confidently said 'no.'
This would be THE best reason to use the starter.
