need help with A/F gage
It splices into the wire between the O2 sensor and the PCM... on my friends 99 firebird it was actually the purple wire that runs into the PCM... I dont know if its the same for camaros...
THANKS
Don't potentially mess up your PCM's reading of your o2 sensors, by splicing into the wiring. Narrow band is worthless. Go wideband, you can get an AEM Uego around 250 on ebay new. The guy who owned my car before me, had narrowband installed. When I went to tune it after my head and cam swap, my o2 were only reading .400mv removed all his wiring and resoldered and they started to cycle like they were suppose it. Plus those sensors are designed to cycle very high and low fast for the PCM's own information, when you do hook it up all it will do is bounce around any ways.
ok i've bin reading and yes the A/F gage i got sucks but i allready opened it and i need to fill the hole in my pod anyways so for now i would like to hook it up, at least till i get a wide band. so can some one tell me the safest way to hook up the A/F gage, im gussing that the wire loom on the driver side fuel rail with the purple wire is not a good spot? please help i got to get this done today!
THANKS
THANKS
You need a pigtail that installs between the O2 and the factory connector and has another wire coming out, so you don't have to splice any wires or screw up the PCM's signal. I have seen them from Speed Inc but I'm sure some one else has them. I think they are like 20 bucks.
