Bad Vibration
Old 04-30-2008, 09:30 AM
1BDBOTI's Avatar
Default Bad Vibration
When I hit about 80 MPH i am getting a bad vibe in the car, I dont know if it is the drive shaft or what..... I just rebulit the mototr and put new trans and conver. in it. I am thinking either i lost one of the wieghts on the dive shaft or maybe the u joints are bad????? Any ideas.... I aslso put a tunnel mount tourqe arm on it to..
Old 04-30-2008, 11:49 AM
qwk93ta's Avatar
Could be your pinion angle.....
Old 04-30-2008, 12:01 PM
heavy6.0's Avatar
could also be converter bolts, flywheel bolts. check out the cheapest and easiest things first, pinion angle adjustment, u-joint nuts, tire balance, etc.
Old 04-30-2008, 09:34 PM
Shooter_Jay's Avatar
could have lost a weight on a wheel too.
Old 04-30-2008, 09:50 PM
Pretyflywiteguy's Avatar
LT1 or LS1?
the steel driveshafts are known for vibration at around 90+
Old 04-30-2008, 10:42 PM
throttlejunkie1's Avatar
There was a recent post like this in the LT1-LT4 section.
Old 05-01-2008, 09:16 AM
1BDBOTI's Avatar
It is a ls1
Old 05-01-2008, 09:17 AM
1BDBOTI's Avatar
I will start checking all the above
Old 05-01-2008, 09:18 AM
1BDBOTI's Avatar
what is the stock pinion angle adjustment
