shreveport/bossier hang out!
#781
I either deleted it or forgot what file I put it in cause I can't find it. I've been playing alot with photoshop here lately and I have to admit, I've made ugly **** lol, but I'm getting better. I touched up a whole lot of pics and made them look really good, but the other stuff like changing designs and adding stuff is what I'm trying to learn.
#787
its an edge converter. we'll see how it holds up. im not gonna beat on it too much. hey CODY, how bout a run before and after the converter.....you up for it??????????
got a great deal on the shift kit so i got it. i will let greg decide exactly what my tune needs to be....its in his hands.
#796
I have a serious leak coming from the steering gear where one of the stainless lines goes into it. Anyone know if there is supposed to be an o-ring in there? I pulled the line and used a q-tip and a small mirror to look inside for any loose/old ring. I found nothing. I tried to tighten it up and that made it alot worse. Anyone worked on this stuff before? I havent. I guess i will go to the autopart store in the morning, or the dealership. There is a steady stream of fluid coming out!
#797
Tough Mudder
Where is the leak coming from? Where the fluid goes in to the rack from the pump?
I don't know about an o ring
Power Steering Fluid Leaks
Step
Action
Yes
No
1
Did you review the Power Steering System General Description and perform the necessary inspections?
Go to Step 2
Go to Symptoms - Power Steering System
2
Verify that power steering fluid leaks are present.
Is the power steering system leaking?
Go to Step 3
System OK
3
Inspect the power steering system fittings.
Are the fittings leaking?
Go to Step 7
Go to Step 4
4
Inspect the power steering hoses.
Are the hoses leaking?
Go to Step 8
Go to Step 5
5
Inspect the power steering pump and the reservoir for leaks.
Is the power steering pump or reservoir leaking?
Go to Step 9
Go to Step 6
6
Inspect the power steering gear for leaks.
Is the power steering gear leaking?
Go to Step 10
Go to Step 11
7
Tighten the fittings. Refer to Fastener Tightening Specifications .
Did you complete the repair?
Go to Step 11
8
Replace the power steering hoses. Refer to the appropriate procedure(s):
* Power Steering Reservoir Outlet Pipe/Hose Replacement
* Power Steering Pressure Hose Replacement
* Power Steering Return Hose Replacement
Go to Step 11
9
Replace the power steering pump or reservoir. Refer to Power Steering Pump Replacement or Remote Power Steering Fluid Reservoir Replacement .
Go to Step 11
10
Replace the power steering gear. Refer to Power Steering Gear Replacement .
Go to Step 11
11
Operate the system in order to verify the repair.
Did you correct the condition?
Step
Action
Yes
No
1
Go to Step 2
2
Go to Step 3
System OK
3
Go to Step 7
Go to Step 4
4
Go to Step 8
Go to Step 5
5
Go to Step 9
Go to Step 6
6
Go to Step 10
Go to Step 11
7
Go to Step 11
8
Go to Step 11
9
Go to Step 11
10
Go to Step 11
11
#798
I wish I was working on my car, but I had to work. Gonna get started on it today though. Hopefully have the rear, rod bolts, oil pan gasket, plugs, and wires done before wednesday. It's gonna be tight though. Would like to get it together before friday in case the rain holds out so I can go and run it.
