NANO Nitrous Blemish Special
Old 12-02-2008, 02:53 PM
Brad@NANODirect's Avatar
Default NANO Nitrous Blemish Special
The 4500psi kits are dated 8 of 06, so they need to be re-certified in 8 of 09 (see pic). They will be re-certified before shipment. The bottles are brand new. Th 3000psi bottles have light surface scratches. We are selling these as complete kits, which includes everything you need to use them. These are being sold first come, first serve.
If you want one please send money to blwnstang02@yahoo.com with address, phone number, ls1tech name, and current nitrous setup with whether its a plate or nozzle with current jetting. You can also call 785-331-2390 or got to www.nanonitrous.com for more info.
A NANO Valve can be purchased with these for an additional $40.
1. 10# 4500psi Universal Kit (Good to 350 nitrous hp) $400obo shipped
2. 10# 4500psi Universal Kit (Good to 350 nitrous hp) $400obo shipped
3. 10# 4500psi Universal Kit (Good to 350 nitrous hp) $400obo shipped
4. 10# 4500psi Universal Kit (Good to 350 nitrous hp) $400obo shipped
5. 10# or 15# 3000psi Universal Kit (Good to 250 nitrous hp) $330obo shipped
6. 10# or 15# 3000psi Universal Kit (Good to 250 nitrous hp) $330obo shipped
7. 10# or 15# 3000psi Universal Kit (Good to 250 nitrous hp) $330obo shipped
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
Every kit includes the following
Old 12-02-2008, 03:26 PM
Brad@NANO Direct's Avatar
pms returned
Old 12-02-2008, 04:27 PM
bad6as's Avatar
if i got one of these
would i need a new valve on my hsw bottle
Old 12-02-2008, 05:25 PM
daniel6718's Avatar
ive got 2 10 pound bottles can i get one 15 pound kit and split the line to my 2 tanks? whats the downfall that the nano will go empty right before my bottles?
Old 12-02-2008, 05:32 PM
jdiddyws6's Avatar
How often do you have to refill the nano tanks? every time you refill nitrous?
Old 12-02-2008, 08:06 PM
Braunbeck's Avatar
figures.......... just spent my loot for the next month.
Old 12-03-2008, 08:00 AM
Pm returned
Old 12-03-2008, 08:03 AM
Our system will not work properly at all when split off. If you split it off the volumes of the air go down per nitrous bottle. Therefore the flow will not stay consistent or hold pressure.
Old 12-03-2008, 08:09 AM
Yes you need to have a full nitrous bottle vs. full nano bottle.
Old 12-04-2008, 01:18 PM
Christmas Special all items are 15% percent off listed price. Whiles supplies last!!!
Old 12-04-2008, 06:04 PM
bad6as's Avatar
is that 15% off the price listed in the 1st post?
Old 12-04-2008, 06:10 PM
SSPerformance's Avatar
do you still need to run a bottle warmer to get ur bottle Presure close for the nano work? Like on a cold day when u turn the bottle on and its 550psi.
Old 12-04-2008, 06:21 PM
You are correct!
Old 12-04-2008, 06:22 PM
No bottle heater needed!!
Old 12-04-2008, 06:24 PM
How much does this effect tune up?
Old 12-04-2008, 06:38 PM
The NANO system flows 20%-25% more overa standard system. The reason being when you heat a bottle the nitrous goes into vapor form. With the NANO you get the same pressure at a cooler temperature.
So if you want more power we will add 20% more fuel on your current jetting. If you want the same power we will take away 20% of nitrous off your current jetting.
Old 12-04-2008, 06:46 PM
do u guys have any jet calculats for DP irect port setups?
Old 12-04-2008, 07:18 PM
1BADAIR's Avatar
so, If I have to change bottle's at the track I would also have to change the nano bottle?
Old 12-05-2008, 07:52 AM
We will give you the tuneups you are looking for upon purchase.
Old 12-05-2008, 07:54 AM
Yes it is made to be a 1 to 1 ratio. You also recieve double the runtime over a standard system. A lot of our customers either by 2 NANO bottles or you can rent a HPA mother bottle fairly cheap to refill the NANO.
