Need help with gauges before buying.....
Im a newbie to nitrous and have the kit all installed but was wondering what would be the most beneficial and helpfull gauges to have. I keep seeing wideband and dont really know what that is or if i need it only spraying 75-100 shot. And were are the best and cheapest gauges at. And last thing do they make a pillar for a hardtop or will i have to just rivit one on my stock pillar. Im not a big time racer or track guy just like to make my car fast and look good so really just getting gauges because i like them. thanks for any advice guys.
[QUOTE=Nitro Dave's Nitrous Outlet;10880292]A wideband gaige is helpful with the right wideband. Other two major options are fuel pressure and nitrous pressure.
what about boost??
what about boost??
The two are not usually the same. I use Autometer, but there are others out there. Just remember the price of your engine versus the price of the gauges that indicate its health.
I can't help you there. The ones I saw were only for t-tops.
I would go WB AFR (this will help you with tuning) and Nitrous Pressure.
Nitrous pressure is important for getting the correct AFR. Bottle pressure to low, you will be rich, pressure to high likely Lean.
The WB AFR will also show you if your fuel pump is up to speed, if your pump or injectors are lacking, this will be indicated by the WB being lean...
Any of the autometer gauges will do. I know there are several other gauges out there, but for the most part it seems like any of the quality gauges are all around the same prices. Def. go with the nitrous pressure and fuel pressure gauges.
LS1TECH Sponsor
We sell a a/f shutdown which works extremely well which is nice to have in addition to the gauge but the wideband helps beyond just the nitrous. Many things can go wrong with any setup and a lot of times this will affect the a/f. Does not tell you what is wrong just tells you to start checking.
Dean
I like getting my gauges from Dynotune. The price is decent, and the guys over there are good to deal with. I got my A/F gauge, nitrous pressure, and fuel pressure gauges all from them. Not to mention they have them in blue which matches my interior LEDs.
I would go with a wideband and nitrous pressure thats what most of our customers seem to buy running nitrous. Best and cheapest thats a challenge. Our gauges are far superior in quality and accuracy than others at even higher pricing. If you saw an autometer or other gauge next to a dynotune gauge you will be amazed. Ours are billet construction with an extremely accurate sending unit that is manufactured in the US. We tried the overseas units but they did not give us the accuracy, longevity and quality we require.
Dean
Dean
Once you get your A/F dialed in on the dyno it won't vary too much. What will def. help is a controller like our microedge that has lean/rich shutdown switch. Rather then relying on looking at a gauge, the microedge will shut your system down if you go too rich or lean. Personally, i would rather rely on that then peeking my eye over at a gauge.
The other issue is its easy to say I am not going higher than a 75-100 shot and after a few bottles (nitrous or Beer) jetting up. Which would make the old tune suspect to new conditions...new jets are cheaper than a Sam Adams Twelve pack ya know...
Dynotune gauges work great. Watched them build a few at their old shop when I got my first system
If I was putting a new system together...say for the wife's new 2010 Camaro I would probably do a Dynotune (Innovate) LC-1 WB combined with a Microedge...Now if they only offered the SS in imperial blue metallic or aqua blue metallic ME-> <-GM
wouldn't the lean/rich shut off in the microedge be more effective (accurate) from a wideband vs a factory narrowband input ?
The other issue is its easy to say i am not going higher than a 75-100 shot and after a few bottles (nitrous or beer) :d jetting up. Which would make the old tune suspect to new conditions...new jets are cheaper than a sam adams twelve pack ya know...
Dynotune gauges work great. Watched them build a few at their old shop when i got my first system
If i was putting a new system together...say for the wife's new 2010 camaro I would probably do a dynotune (innovate) lc-1 wb combined with a microedge...now if they only offered the ss in imperial blue metallic or aqua blue metallic me-> <-gm
:d:d:d
Ok i have made up my mine i am going to get the microedge from HSW and the Nitrous pressure and fuel pressure gauges from Dave. Thanks for all the help.
