440 LS7 and some spray!
What do you guys think about spraying a 440 with a 4.130 bore and a 4.100 stroke. Seems like lots of people and builders are saying not to spray them because the piston pin is moved up close to the top of the piston, and something about the wall thickness.
I would like to build a 440 and spray a 150 to 200 wetshot at the track only.
Can someone clear this up for me? Anyone doing it? Results also, but not necessary.
Thanks
-Kenny
Thanks
-Kenny
Depending on what piston/ring pack was used you can spray a 4.10 stroke motor, just not with alot. A 150 would be fine, but tune up needs to be spot on as the piston gets thin on the longer stroke stuff. Mine is a 4.070 bore 4.100 stroke built by HKE and will see a lil spray.
Thanks
-Kenny
Thanks
-Kenny
Mike
I am not sure, i am leaving that up to the builder. I do know i will be using Callies Rods. I heard something about 6.125, but i could have mstaken that.
What about the LS7 wall thickness. It will be a 4.130 bore.
I was thinking of turbo with an S480 & 408, but i did run into transmission problems i wanted to stay A4 and not bang out the trans tunnel...
my buddy has a hke built 440 ls7 geting ready to bump the shot up to 250 currently running a 200 putting down 670 through a auto unlocked. That thing is fast i hope to get my stock cube that much but more nitro.
Most shops will not stand behind a motor that big on spray I think thats alot of the reason not too many are building them. I personally would not spray a 427 or larger. Some ppl may not remember the small block 400 with no water jackets between cylinders. They broke often. Whenever you have cylinders touching(or close to touching) You will have heat issues and thats what takes the rings out most of the time.
You are correct that some pistons are not rated to handle much nitrous. The issue with having the pin high up is that normaly the piston rings are as well. Just a small amount of detonation with a high HP application on Nitrous could crush the ring landing. So like said above you could spray something like 150 and bo ok. I would not spray alot and the tune does need to be correct..
Dave
Dave
