Best dry nozzle to mount post MAF
Old 06-23-2009, 05:00 PM
DOUBT IT's Avatar
Default Best dry nozzle to mount post MAF
I'm slowly coming along with gathering parts for my kit, and I'm wondering what nozzle to go with. It's going to be a 75 or 100 dry shot post-MAF.
Currently I have a NOS wet Fogger nozzle. I don't want to block off the fuel side and use it that way. Incidentally, I have that nozzle to swap or sell if someone wants it.
What I plan to do is mount the nozzle into the MAF housing post-hot-wires ( into the clamp band most likely ) and use the HSW Interface to handle the fueling.
I have a bag full of NOS jets that I'd like to be able to use as well.
Any of you guys have any insight? I'm about to start buying parts again now that my wife has a job again.
Old 06-23-2009, 05:23 PM
Noxious's Avatar
I think most of the dry guys will say the harris plate is the best for dry shots post maf although I'm running a plain old nozzle myself
Old 06-23-2009, 05:51 PM
DOUBT IT's Avatar
I don't want a plate, just a simple nozzle. I'm not going to spray more than 100 shot with this setup.
Old 06-23-2009, 07:50 PM
Brian Coles's Avatar
So where do you plan to mount the nozzle?
Old 06-23-2009, 08:05 PM
860 Performance's Avatar
no dry nozzle is any better than an other. Since you already have a bunch of NOS jets then Dynotune would be a good option because I know they use NOS style jets.
Old 06-23-2009, 08:08 PM
DOUBT IT's Avatar
In the rear half of the MAF housing. I'm going to drill and tap the aluminum.
Thanks, I'll take a look at them.
Old 06-23-2009, 08:27 PM
Take a pic of that nozzle install for me! I'm running the nozzel pre maf and looking to go post but thought plate was the only wat to go? How different is the shot between your plan and a plate?
Old 06-24-2009, 09:28 AM
Mike@HSW's Avatar
Our nozzles also use NOS style jets so you will be ok going with ours.
Old 06-24-2009, 10:04 PM
BobDoLe's Avatar
i have a HSW 70 degree nozzle in one of those hated SLP bellows. i mounted it under the bellow to sort of hide it from anyone taking a quick look.
