Where to hide solenoid, lines, nozzle.
I'm going to be running a fogger nozzle on my dry setup and I'd like some suggestions as to where to hide the solenoid and lines.
I've thought about running the line out through the hole by the pcm and under the cowl. Then putting the solenoid under the cowl and a line up under the fuel rail to the nozzle going in just ahead of the TB in the bellows on the bottom.
I've got the HSW interface and microedge on order so I don't need it in front of the maf.
I don't really want a plate because it's a dead give away.
If anybody else has some better suggestions let me know
Dang that's a good spot and probably wouldn't get as heat soaked as over the engine. Thanks a lot shockwave I searched for like an hour and that's the best spot I've seen on here. I feel dumb that's soo obvious.
Nick, have you seen any places to hide the interface?
The best spot is inder the base to the lid there is some plastic webbing the noid fits nicely under there. you can get an anular nozzle and its basically flush with the filter. run the feed line either threw the fender or with the pcm wires and put bigger lume on it. the controller can go in the glove box or again uder the filer base. ATv's car was like this and people never found the kit.
