New PB thanks guys
Old 06-28-2009, 10:18 PM
Z-RATED94's Avatar
Default New PB thanks guys
Shiztiny, ATVracr, Larry (SpeedInc.) Took your advice, leaned it out and took some timing out. Old best was a 10.89, new best 10.75 in worse air and with a slighty worse 60ft. Thanks for the help. Rick
Old 06-28-2009, 10:23 PM
Z8'S's Avatar
Congrats Rick! I heard there was also a new record run at Byron today.
Old 06-28-2009, 11:29 PM
Z-RATED94's Avatar
Thanks Chris. I can't believe I was there and missed it.
Old 06-29-2009, 01:04 AM
camscam02's Avatar
how much timing and what jets did you use?
Old 06-29-2009, 08:51 AM
ShiznityZ28's Avatar
That might be the first time i was ever called "Tiny'. LOL Glad it helped man. if you put some plug pics up i bet we could get some more out of it.
Old 06-29-2009, 09:17 AM
ATVracr's Avatar
Congrads!
Old 06-29-2009, 10:02 AM
Z-RATED94's Avatar
Hey, at least I had the right letters in there, just the wrong order. Thanks Steve, and the next time out I'll post some plug pics.
Old 06-29-2009, 10:19 AM
Z-RATED94's Avatar
I don't have a big jet selection, so instead of going down on the fuel jet I upped the nitrous jet. Went from the 62N to a 67N and left the 38F jet alone. Went from pulling 5 degrees to pulling 9 from my base of 33.
Old 06-29-2009, 11:59 AM
67 38 is probably close. id go 36 if you can and pull 2 more degrees to see if it likes it. mph will tell the story.
Old 06-29-2009, 12:07 PM
Z-RATED94's Avatar
I do just happen to have a 36, plus I'll order some more sizes. I have a new set of the non projected 7's, but I'll have to pick up some more. That and some decent gloves so I can pull and read the plugs after a short blast and shutting it off as you said.
So once the fuel ring looks good I then start putting some timing back in, while keeping an eye on the fuel ring?
Old 06-29-2009, 12:26 PM
ATVracr's Avatar
Was there a timing mark on your plug with the current jetting?
If not just pull the fuel out, if there is then pull the 2* out like Steve said.
Old 06-29-2009, 09:15 PM
Z-RATED94's Avatar
I'm not gonna lie, I didn't put the TR7's in yet. Still had the 6's in and some 104 unleaded in the tank. I will next time before I go and bring some extras with. I need the gloves and a shorty socket so I can do this on the return road. I'm just a small dog with limited resources.
Old 06-30-2009, 06:16 AM
ATVracr's Avatar
I've pulled many plugs on the return road.
Old 06-30-2009, 06:57 AM
I hear ya. header wrap helps alot even if you only do 4-5" on each tube.
Old 06-30-2009, 11:38 AM
Z-RATED94's Avatar
Good idea, I'll put that on my parts list. On another note, I still can't believe I was at the track and missed the record setting run by JakesZ28. I had no idea he was there and was about to be the first LT1 on juice to break into the 8's. In crappy air no less. 2600-2800 DA
Old 06-30-2009, 12:25 PM
LS1 SPEED's Avatar
congrats again and glad to help
Old 06-30-2009, 12:39 PM
Z-RATED94's Avatar
Just remember, your not done yet!! LOL Cause like they say, is it really ever done? I'll stop buy tomorrow to order a few more parts.
Old 07-01-2009, 11:27 AM
LS1 BU's Avatar
Not to bust your bubble but it seems like the gains were from adding more nitrous. The Da did suck. What A/F are you seeing on a pass. I would get those tr7's in. I sprayed 200 on TR6's once. I melted the tips off with 10 degrees of timing out. It cost me a stock bottom end. I here they are like glow plugs. I now drive the car N/A with the tr7's and spray it. I have learned alot from ATV and shiznity. Pull alot of timming with correct plugs and dial in the A/F. Congrats on the new best.
Old 07-01-2009, 11:44 AM
LS1 SPEED's Avatar
lil bro
you lost a motor from a TNT fuel solenoid failure if I recall correctly + the fact of over 600rwhp with an auto on a stock block probably didn't help
Rick's car would make more power weather he leaned it out from fuel or added nitrous, so whichever way it is it worked. We like to go the nitrous route as well
now you should be doing good and need to get your turd on the hose again
Old 07-01-2009, 11:59 AM
Z-RATED94's Avatar
Thanks Charlie, I agree with what your saying about the larger nitrous jet. The point is though, it needed to be leaned out some more. The oringinal jetting was a 62N 41F. Saw some gains by putting the 38F jet in. I think I could have run a 36F with the 62N and saw the same gains as the 67N 38F. I'm just happy to be making some headway.
