New Setup: Daves Plate and HSW Standalone
Old 07-02-2009, 10:49 AM
mattl31's Avatar
Default New Setup: Daves Plate and HSW Standalone
Hey guys just thought id throw up some pics of whats been keeping me busy lately. the basics are:
Nitro Daves 78mm wet plate (currently jetted for a 150 shot)
3/16" Stainless hard lines from solenoids to plate
Harris Speed Works dedicated fuel cell polished by yours truely
6AN feed lines to both fuel and nitrous sides
a big thanks the Jeff (jmm98ls1) for letting me use is bender and flaring tool for the hard lines, and putting up with me. also to DopdBrd, for letting me install the standalone before it was paid for lol.
car went 12.0's on the motor, and i'm hoping to be deeeeep into the 11's with the nitrous, and bumping the shift points to 7000 rpm.
anyway here are some pics...thinking about pulling the decals off of the purge and nitrous solenoids so they all match btw.
Old 07-02-2009, 02:06 PM
Mike@HSW's Avatar
very clean engine bay, really like what you cooked up.
Old 07-02-2009, 02:30 PM
LS1RedZ's Avatar
I like the setup. VERY clean install man.
Old 07-02-2009, 02:44 PM
Chris@NitroDaves
Guest
Posts: n/a
Damn clean install you got going on there....
-Chris
Old 07-02-2009, 03:12 PM
mattl31's Avatar
thanks a lot guys. a lot of thought went into everything! wouldn't be possible without such great products.
Old 07-02-2009, 05:29 PM
GMTECH4's Avatar
what a super clean engine bay notice the a/c drier, throttle body, and abs unit looks polished.
Old 07-02-2009, 05:44 PM
mattl31's Avatar
thanks man!
battery cover, pcm cover, hood struts, ac dryer, abs block and brake lines, and standalone fuel cell are all polished. the throttle body is charcoal gray along with the MAF delete tube.
Old 07-02-2009, 06:08 PM
black01_WS6's Avatar
any better pics of the stand alone? also how much does that one hold?
Old 07-02-2009, 06:58 PM
Z-RATED94's Avatar
Very very nice. Why bump up the shift points though? Are you going to run out of rpm on the nitrous?
Old 07-02-2009, 07:57 PM
mattl31's Avatar
i can get some for you. it holds just under a gallon of fuel
bought some katech rod bolts. planning on shifting it around 7000
Old 07-02-2009, 08:04 PM
Z-RATED94's Avatar
Nice, but if you don't need to, go easy on the rpm. On the juice with all that torque it's not as important as an NA motor, or so I've been told.
Old 07-02-2009, 10:15 PM
ls2 bait's Avatar
looksery good man. similar to mine but my solenoids are mounted lower.
Old 07-02-2009, 10:45 PM
mattl31's Avatar
thats a good point!
if all goes according to plans i'll have a NA tune and a N2O tune, that way the NA tune can be optimized (higher RPM, more timing) and the N2O tune can pull some timing and maybe shift it a little short
Old 07-02-2009, 11:38 PM
Z-RATED94's Avatar
thats a good point!
The same here, I need to send off my other computer to get my NA tune back on track. My shift points for the nitrous really threw off my NA times. Plus I want to try a little more timing NA. I have the base timing on this computer set at 33 and pull timing with a 685 box. I don't want to mess with it as I swear sometimes altering a setting and then trying to put it back doesn't always work out like it should.
Old 07-03-2009, 12:01 AM
mattl31's Avatar
no kidding man. 2 optimized tunes seem to be the way to go. especially since i want to have it be as ballsy as possible NA just for screwing around town and such. i think im at 28 degrees total timing right now on mine.
Old 07-03-2009, 06:40 AM
z28rob18's Avatar
very clean car you got there. should run some good #s too. anymore pics of the stand alone?
Old 07-03-2009, 09:20 PM
ls2 bait's Avatar
you can tune it with efi live and then you can use the cos5 to have a seperate tune for nitrous or na.
Old 07-04-2009, 01:49 AM
mattl31's Avatar
thats what i've been checking into....unfortunately my tuner uses hptuners
Old 07-04-2009, 07:14 AM
rpmauto's Avatar
very clean install. HOw did you get the slp bellows to fit with the plate kit?? I had one and it wouldnt fit even trimmed the crap outta it. Stock bellows wont work, i have a intake hoses .com one now, trimmed the crap outta it, fits, but doesnt look as nice.
Old 07-04-2009, 07:15 AM
rpmauto's Avatar
nevermind, i see you must be speed density. I may end up going that route
