Uncorfortable with nitrous tune
Old 08-30-2009, 07:06 PM
RealLiveMD's Avatar
Default Uncorfortable with nitrous tune
I took my car in for a nitrous tune yesterday. I'm running a 125 shot. The NA tune was at 11.5 to 1 and 25 degrees timing. The tuner changed the A/F to 12.8/1 and this was the best we got. I'm uncomfortable with how the a/f is so rich until its below the computers ability to read. I'm runnig 116 in a standalone and 125 nitrous pill with 100 fuel pill. The tuner said that if I went with a small fuel pill that the car would be too lean. So this is the best we got. I'm uncomfortable because the power is low and my graph doesn't look like anyone elses. Chime in. Give me comfort or complaintsUncorfortable with nitrous tune-img_1243-wince-.jpg.
Old 08-30-2009, 07:13 PM
Powerhouse's Avatar
That picture is really small.
Old 08-30-2009, 07:24 PM
RealLiveMD's Avatar
my first time trying to post a pic try this one
Old 08-30-2009, 07:26 PM
TheInferno's Avatar
im not an expert on tuning of any way shape or form, but doesnt the curve being wavy indiicate detonation?
Old 08-30-2009, 07:39 PM
dkbmxer002's Avatar
i ran a 125 shot for 30k HARD driven miles on a stone stock tune....
Old 08-30-2009, 07:40 PM
RealLiveMD's Avatar
Don't know, I hope someone can tell us.
Old 08-30-2009, 07:53 PM
dkbmxer002's Avatar
what is your setup? and is it only a 125 shot or multiple stages?
Old 08-30-2009, 08:13 PM
RealLiveMD's Avatar
one stage. HSW plate kit on 400rwhp NA car. standalone C16
Old 08-30-2009, 08:53 PM
dkbmxer002's Avatar
is there any reason you are running c16 for only a 125 shot? what is your compression? honestly i would think you are being WAY to safe with c16 for only a 125 shot at 500-550hp...
Old 08-30-2009, 09:25 PM
RealLiveMD's Avatar
I'm guessing stock compression I have 214/230 .601/.575 117 , ported 243's, Lt and all bolt ons. The standalone, c16 and everything else was bought based on suggestions. I spend whatever to make it safe.
Old 08-30-2009, 09:56 PM
JAX04's Avatar
nothing wrong with c16 in the stand alone, it can only safe gaurd against detonation, but then again, im no expert. i always try to shoot for around a mid 11 afr when im sprayin. just my 2 cents.
Old 08-30-2009, 10:17 PM
dkbmxer002's Avatar
i just feel like c16 mixed for a 125 shot is way too much overkill for a stock compression 400hp n/a motor. i could be wrong, i am sure someone who knows much more will post up.
Old 08-31-2009, 08:38 AM
ATVracr's Avatar
Are you sure the bottle was good?
If the jetting was that rich it should show it sooner but maybe not.
Before you go changing a bunch of stuff put a fresh bottle in it and make sure the pressure is right.
Only making 80hp on 125 jets isnt good.
C16 in the stanalone is fine, when you get the tune dailed in it should let you run a couple more degrees of timing.
Old 08-31-2009, 02:23 PM
RealLiveMD's Avatar
Supposedly my tune is dialed in. This is what I got after the tune.
Old 08-31-2009, 02:55 PM
Z-RATED94's Avatar
He asked if the bottle was full and the pressure was correct. If it was (I'm no expert either) the tune looks a little scary and I personally wouldn't use the spray until the tune looks better.
Old 08-31-2009, 03:07 PM
ATVracr's Avatar
Did they pull plugs? What plugs are you using?
You need to take it to the track, make a 1/8th mile pass and pull the plugs.
Dyno's can get you in the ball park but there is no way its "dailed in".
Anything under 11.5 A/F is real rich IMO on a 125 shot.
We run our 175 shot at the same A/F we run on motor, 2nd stage is richer.
Old 08-31-2009, 05:40 PM
RealLiveMD's Avatar
Plugs are tr6's, gapped at .035. plugs haven't been pulled. bottle weighed 17 pounds at the end of the pull. pressure was up to 1050 before the pull.
Old 08-31-2009, 05:55 PM
JonCR96Z's Avatar
17#s? Isn't that pretty much empty?
Old 08-31-2009, 11:52 PM
Z-RATED94's Avatar
That's probably your problem right there. Get a full bottle and check it out again. You can't have a bottle that low and expect decent results.
Old 09-01-2009, 12:31 AM
02_ramair_ta's Avatar
What fuel sys you running, are you using a FPSS? Also having low to no bottle left, can really make you run "soft". It might read 1050 at the start, but that can all change pretty quick when she is empty.
