Nos dual jet ???? Please help
Old 11-18-2009, 12:17 PM
98mysticZ's Avatar
Default Nos dual jet ???? Please help
... i have the harris speed interface... and i am running a 5177 kit split noids and have a .063/.065 jets in them... now whats the rating on the shot size with these 2 jets?... when i put it into the nitrous calculator (the jet one thats linked on the site) it tells me 380ish? now i got almost 200 wheel but it was LEAN AS HELL... and i only had the box set up for a 180 shot... so do i need to turn the box up or what?
Old 11-18-2009, 01:59 PM
98mysticZ's Avatar
come on guys help me out please....
Old 11-18-2009, 02:28 PM
ryarbrough's Avatar
a 63 should be like 150 wheel @ 900-950psi I assume you are running dual dry so somewhere around 300 total
Old 11-18-2009, 04:13 PM
98mysticZ's Avatar
yea just got off the phone with NOS and they said the same thing.. well i guess my math got messed up some where and i flipped the harris box to 180 for some reason thinking it was a 200 wheel shot... SOOOOOOOOOOOOOOO i am going to set the harris box up MAXED out and see where my a/f goes and play from there
Old 11-19-2009, 02:26 PM
Race your car!
JL ws-6's Avatar
A 5177 kit has basicially 2 purge solenoids on it, and won't flow anywhere near the power you think it will.
With no jets at all it maxes out at about 200 rwhp if I remember correctly.
Now, if you put some bigger noids on there, and upgrade to a-6 line you can spray way more then I would try to do thru the intake in that fashion that's for sure.
Personally, once you get to the 200 hp level, IMO you need individual cly tuning ability.
Old 11-21-2009, 04:56 PM
98mysticZ's Avatar
well i dropped pill size to .045's and its STILL LEAN no matter if the harris box is used or i set the box at 300... its still lean..... i dont know what the hell to do but go wet shot and call it a day......
Old 11-21-2009, 09:18 PM
daniel6718's Avatar
want a fogger and stand alone? if your goana wait a few months then ill have my stuff up for sale
Old 11-22-2009, 10:59 AM
98mysticZ's Avatar
might.. i was lookin to buy it next month... but let me know... shoot me a pm
Old 11-22-2009, 02:16 PM
Race your car!
JL ws-6's Avatar
What are you calling lean?
Old 11-22-2009, 08:31 PM
98mysticZ's Avatar
13.5 i lean to me for that kind of power
Old 11-23-2009, 09:27 AM
Nick@HSW's Avatar
What do the plugs look like after a pull? You sure the wideband is good?
Nick
Old 11-23-2009, 09:42 AM
Race your car!
JL ws-6's Avatar
13.5 isn't too lean if your timing is right, you have enough octane in the fuel and your running the right heat range plugs.
I'd like to see some plugs after a hit and see what they look like. Also like to know what fuel, what plugs your running, compression both static and dynamic.
The 13.5 a/f, what are you getting that from as well, and how old is the O2 sensor itself that you are using?
Old 11-23-2009, 06:15 PM
98mysticZ's Avatar
plugs look fine to me didnt get into them with a magnifying glass but seemed ok.. and they are tr6's had some 7's in it and the foweled out with street driving.. and i am just running pump 93...... and the wide band is am aem with less then 200 miles on it.. and i belive the compression on the motor is 11.2-5 if i remember correctly....( 408, stock deck height stock 6.0 gm gaskets 317's -2cc piston and a texas giant cam) .... and the wide band is placed in the x-pipe of a texas speed true duals... i mean when i sprayed it with the .065/.063 it seemed to surge alot.. felt like i was in and out of the gas on the bottle but i didnt get an a.f reading on it.. didnt have a gauge then and the one on the dyno was broken.. but put down 673/742 on the dyno.. and went to .055/.053 i belive and it did 630/669 no surging and 13.5 a/f....the only thing i am not 100% sure of is how much timing the car has.. i dont have hp tuners but i belive we took out like 6-8 degrees
Old 11-23-2009, 07:28 PM
Race your car!
JL ws-6's Avatar
your running too hot a plug. If the #7's are fouling out it's because your part throttle tune is junk and needs to be cleaned up. Honestly, with 11/5 to 1 compression you should be running a #7, maybe a #8
You may have an inadequate fuel supply, that could be causing the surging as well. Timing could be too high, alot of possible causes to the problem. If you have a FPSS on the car shitcan that thing too, they never work right and are 99% of the time a headache, epsecially with on/off/surging type issues, damn things will make a kit come on and off just from vibration.
If the car isn't tuned in open loop, that's definitely causing problems, nitrous and o2's don't get along from my exp all that well, especially when you get into fully built motors and whatnot.
You have a tuning problem, not a lean condition. Get the tune right so it will drive on the #7 plug without any problems, then start there.
Old 11-23-2009, 07:56 PM
98mysticZ's Avatar
will do i am gettin hp tuners at christmas.. was just gonna switch to a wet kit but i have ALWAYS RUN DRY since like 00 lol on all my thirdgens..... i thought it might have been a tunning issue but wasnt sure... i wanted to run around on the 7's but got less then like 1k miles out of them so i bet it was the part throttle stuff.. i still might go to a wet kit.. but we will see at christmas
