Anyone with Direct Port spraying 150 hit..
Why spend all that money to make it a waist? There isn't any good reason to spend all of that extra money for such a small shot. If you want the best set up for 150 hp then a plate is plenty to spend and support it.
Now on the flip side of the coin if you are using this a stepping stone and plan to drop a second stage of another 150 hp later on then go for it. If you don't ever plan to spray more than 250 then there isn't any good reason to spend the money and time for DP.
Using the LT1 intake you would be good with our plate up to about 200-250.
However if you are just looking at the fact you only want to do this once and may want more in the future or just simply want the look of the directport I understand going that route now. Its always cheaper to do it right the first time. The Directport would actually be better for anything over the 200 mark but 150 is no problem. I would suggest using a dedicated and changing the fuel pressure to the nitrous system to 10psi so that we can use a larger orphase hole on the fuel jet.
Dave
Dave
I will be using this as a stepping stone. Right now I really wanna see what she can do on pump gas. I think if I put another fuel pump in the cell and put a microswitch at WOT it will handle a 150 hit on pumpgas.
I just ordered a direct port this morning. 4solenoid with rails. I only plan to spray 200, and I know the plate would be fine. I bought it because I've always wanted one. I like the ability to adjust each cylinder, but the reality is if I hadn't bought it I'd always wish I did.
My self I am a big fan of value. So direct port isn't much of a value for a 150 shot.
But if you put a high value on having the direct port then it is well worth it for you. Also a stepping stone is your best bet to start out right. It will work just fine but for me the extra money spent would go elsewere. Your budget your car, your awesome set up. Good luck and let us know how she runs!
Also props to quote for just a good post.
