Price list for NX DP Project
Old 12-16-2003, 07:19 PM
Zero_FactiX's Avatar
Default Price list for NX DP Project
I've been doing my research with all the kits and pricing and I've made a list of everything that i'm gonn need to do this please let me know if i'm missing anything.
NX DP Kit $808.00
GenX-2 Kit $360.00
Holley "Blue" Fuel pump $106.00
Fuel Pressure gauge $200.00
Fuel Cell $100.00
Misc Hoses fitting etc. $50.00
Grand Total $1624.00
Planning on saving up so I can have all this by early next season. If anyone know's any cheaper pricing please PM me.
Old 12-16-2003, 07:23 PM
monkeyboy's Avatar
dude, just go with part NX DP #80010. it uses your stock fuel rail and is about $500 bucks cheaper than the route you are going.
Old 12-16-2003, 09:33 PM
Where could did you find that at?
Old 12-16-2003, 09:34 PM
99taws6's Avatar
Cheaper in the beginning, but far more expensive when you go lean and you toast your motor... A dedicated fuel system like he has planned is the way to go..... The list you have looks good, but shop around on places like ebay and you can cut those prices down alot...
Old 12-16-2003, 09:39 PM
Yeah that list was for everything new when i build this kit ebay will be my best friend
Old 12-17-2003, 07:16 AM
Super Moderator
Reckless's Avatar
Your estimate isn't too far off, but I would throw a 10% cushion onto that for stuff you forgot. I did a similar setup and it cost about that, but with very good deals on all the parts.
www.cofba.org/users/reckless/dp.html
www.cofba.org/users/reckless/dp_fuel.html
Old 12-17-2003, 07:34 AM
The Bull
DERTY's Avatar
Fittings and hoses is a bit cheap on your list. I'd plan on spending a little more there. Are you running a small return line back to the tank or deadheading the pump?
How much are you going to spray? Only reason why I bring it up is a Holley black may be more appropriate because you can get more out of it. NX Runs a higher pressure tune (9 to 10 PSI) over NOS and the flowing fuel pressure requires a little more oompf for the bigger shots. It might cost you 40 bucks more at the beginning, but it should work out well. If you do that make sure that you get a Holley regulator. Blues come with one and blacks do not. It's a $20 item.
Old 12-17-2003, 09:10 AM
Vents's Avatar
Steve beat me to it.
the hoses and fittings could be as high as 150$ that junk is spen-sive..
Old 12-17-2003, 10:30 AM
so add $100 to the misc junk and $60 and get the black fuel pump that's a total of $1784.00 for the whole setup. I'm planning on starting with a 150 shot but will be going up as soon as i can get more nitrous friendly parts.
Old 12-17-2003, 02:07 PM
Thought of something else I'm gonna need a window switch Modified $130.00
Running total $1914.00
Old 12-17-2003, 02:31 PM
BTL FED's Avatar
I have a set of custom fuel and n20 rails for a direct port, I want 100.00 for, if you are looking for something like reckless has
Old 12-17-2003, 03:18 PM
The Bull
DERTY's Avatar
Are you only going to use one bottle? They are easy to acquire, I already have 5-15lbers in my stock pile and a 10lb bottle. Just kinda pricey though. Depends on how much you plan to go through in a weekend.
Old 12-17-2003, 03:30 PM
00REDZ28 - I'm not ready to start buying everything yet just pricing up.
Derty - Probably 1-15lb on a 150 shot till i get comfortable with everything then maybe 2 and a bigger shot
Old 12-17-2003, 03:50 PM
monkeyboy's Avatar
you can toast your motor anyway you look at it. if you have a nice fuel pump(s), the fuel pressure will drop will not drop significantly to destroy the motor.
zero, you can find the NX DP for $1050 at a few places. the part # is 80010. my buddy got his at speed inc. and its adjustable from 150-300 shot. NX runs that kit on a couple of their project cars AND HAVE NOT BLOWN THE ENGINES ON EITHER ONE.
