Adding Nitrous to my turbo setup... have some questions!
Restricted User
Adding nitrous to my turbo setup... 5.3, 317, ls6 cam, FM MPT70, 14psi and 15*.
I won a single nossle nitrous kit from Nitro Dave I was thinking of running a 35 shot with the turbo for the track..
1) how much will the 35shot equate to with the 14psi of boost? like a 70shot????
2) how much timing do i need to pull? I curently run 15* but have ran 21* for a long time with no problems... think itll be ok where its at or should i pull some?
3) How do i keep the nitrous from engaging while im on the trasbrake?
Is there anything else i should know???
Thanks guys!!!
Thanks guys!!!
Have you thought about spraying the intercooler? It sucks that you wont be able to use the nozzle, but its just a thought.
For every 1* you cool the air charge, you gain 10hp. At least thats what they told us in school, lol. It might add up to more than the 35 shot.
Congrats on winning, by the way.
Restricted User
I did think about spraying the intercooler! but 1*= ~10hp!!! really????? How much nitrous does it use to spray the intercooler for 10 seconds??? lol im a total nitrous noob, lol... do you spray the IC right beofr the run and during the run or just right befor the run???
I dont know how much it would use in that time. But you could wire it up on a wot switch so it sprays just while youre running, or you can just spray it before to save some spray.
If you dont mind me asking, why the 5.3l?
Restricted User
1) cheap as hell lol
2) the shortbock holds up to one hell of a beating in 100% stock form
3) they seem to last longer at the same power levels as 5.7's
4) did i mention cheap? lmao
Ya they are just a proven motor to take a beating and make cheap FI power.... if it blows ill just buy another $400 motor and run the **** out of it! I have like 8000 miles on mine running 14psi and im not nice at all to my motor!
^^Yeah thats it. Sorry about that, that sounds much more reasonable.
It makes me mad when i start forgetting what i learned in school since i cant put it into practice.
Ahh, i see. Thats pretty impressive.
unfortuantley to safely run the system its gonna take more then a simple 300 dollar nozzle kit. once you tack on a window switch(rpm spray range), bottle heater, and WOT your paying some money out of pocket. if I were you id sell the nitrous kit for 225 or so and put that towards a methynol kit which will open up a lot more power and safety to the car.
^ agree with him. There was a big discussion in the forced induction section last week about spraying the intercooler, and turned out that it dont make as much power as everyone thought. If you do plan to keep the nitrous, run the shark nozzle closer to your intake and spray a 50 shot. You shouldnt have to take any timing out but if you do it will only be 1.
Restricted User
Well i though about meth/water injection... but i have had my car up to 19psi and 21* timing with no detonation on 91octane pump gas...
So i assumed i wouldn't have much to gain from meth injection...
But from the nitrous I figured i would get instant spool, and cooler AIT, and a few more horses, lol...
If i have to spend the money for the Micro edge im not to worried about it, as i will be doing it later on down the road, just trying to get some info...
Thanks for all the suggestions/advice guys!!
Thanks guys!!!
Thanks guys!!!
Keep in mind you have many differnet options. You can simply just use a small shot to cool the intake charge and at the same time have a small power increase or you can back down some of the boost and spray more nitrous. I have boosted guys that want more and have reached a point to where they can not get anymore boost use nitrous and back down on the amount of boost.
Also keep in mind that with a boosted application the affect of the nitrous is greater than it would be VS a N/A motor.
I would suggest using our digital windowswitch with built in TPS activation and gear lock out feature. Or you can use our Progressive controller that has all the added features of the windowswitch as well.
This will keep you from spraying at to low of a rpm, give you a safe shut off point if something were to happen, and a way to controll traction.
I would also use our stage 3 accessory package. With these two intems you will have everything needed to safely spray and keep the system fuctioning to its full pontential.
Here is a progressive.
http://www.nitrousoutlet.com/catalog...3&product=4004
Our stage 3 accessory package..
http://www.nitrousoutlet.com/catalog...3&product=3806
Let me know if I can answer any questions...
Dave
Put a 100 shot on it, tighten up the stall on your converter a bunch and spray it on the transbrake. You can shut the spray off when you shift second or come off the brake or when you hit a certain amount of boost (if you want to be easy on the motor).
Restricted User
You are on the right track. A methonal kit will never perform as well as the nitrous system will. I have people swap from methonal kits to nitrous all the time. Dont get me wrong a methonal kit does help but the impact is not near as great as the nitrous system.
Dave
Dave
ya im not familliar with nitrous... but looking at all the safety equipment and accesories i think im gonna wait and save for those items befor i install it...
I think im just gonna us HPtuners and pull like 2* and see where im at...
I will hit you up when i have the funds to buy those accesories... im in the process of buying a house right now so im trying to save all i can.
Restricted User
You are saying to use nitrous while on the transbrake??? wouldn't that be hard on it??? lol
I have never had the car to the track yet as i just got it put together not to long ago...
what can i do to save the oil pan ect... incase it launchs and comes down hard?
