find the right spark plug
I've been running a tr6 plug with my 100shot, I am going to a 200 and Im figuring I should go with a tr7. The bad thing is I dont know a whole lot about spark plugs. There is different types of Tr7 plugs and not for sure which would best suite me. Any info given would be a bunch of help, also if anyone has a write up or something explainning certain spark plugs, that would help me out too. I tried looking in the stickys but couldnt find what I wanted.
9 Second Club/Nitrous Mod
If you're stepping up to a 200 hit, I hope you AT LEAST have a racetronix hotwire kit installed and hope your fuel system can handle it. Make sure you pull timing and I would go with an 8 plug (B8efs, part #1049). You can drive around with 8s if your tune is right.
You better start learning or you'll end up a statistic. Read the nitrous stickies, along with reading in general and hands on experimenting. BUT, there's only a handful of guys here that really knows their ****, so beware.
i always understood going from a projected to a non is worth a full heat range point. can anyone prove this wrong? does ngk use one heat scale. From what know the TR has it's heat range, the BR has it's heat range. when you go TR to BR its -1 right there.
