Does Changing Solenoids mean Changing Jets too?
Old 02-03-2010, 01:52 PM
SkullV's Avatar
Default Does Changing Solenoids mean Changing Jets too?
I got a good deal on some NX Lignthing pro power carbon fiber nitrous/gas solenoids so I'm going to use them in my current nitrous system. It is a HSW ls6 plate system. Just wondering if I need to change the jets for the bigger solenoids or if the current jetting will have the same result?
I think it won't matter, but I just want to be sure!
Old 02-03-2010, 05:32 PM
LS1TECH Sponsor
Grant@NitroDaves's Avatar
If you are using the same injection device, you should not have to change your jetting.
Old 02-03-2010, 06:47 PM
860 Performance's Avatar
Not always true. If the OP is going from a .093 HSW to an .093 NX noid, then Grant your right, that difference isn't going to make any noticable difference.
However if he is jetted at say...150hp or a .062 jet and is going from an .078 noid to a .125 noid, then I gaurentee that he will need to change his jetting after swapping noids.
Old 02-03-2010, 07:23 PM
G Engines's Avatar
If the solenoids flow different than you will need to change your tune up.
Old 02-03-2010, 09:04 PM
SkullV's Avatar
I am going from .125 HSW nitrous solenoid to a .125 NX nitrous solenoid and a .250 HSW fuel solenoid to a .310 NX fuel solenoid. What exactly do I need to change?
Old 02-03-2010, 09:23 PM
Nitro Dave's Nitrous Outlet's Avatar
Vinny brought up a good point... To add to that if your solenoid was having issues opening all the way ior it was flutering it could restrict flow.. There for switching to a solenoid that may not have that same issue could change the amount of flow causing a tune up change..
Best to double check just to be safe..
Dave
Old 02-03-2010, 09:26 PM
ryarbrough's Avatar
Fuel jetting will definately change... Nitrous "should" stay the same. You need to verify both by pulling the plugs after a pull...
Old 02-03-2010, 09:28 PM
SkullV's Avatar
So jet it/tune for a small shot, verify everything, and go up from there?
Old 02-03-2010, 10:25 PM
SkullV's Avatar
You think if I just start with the normal HSW jetting for a 100 shot and go from there it will be alright? The worst that will happen is that I will be a LITTLE rich right? After that I could just use a smaller fuel jet or a slightly larger nitrous jet depending on what the plugs say right?
Old 02-04-2010, 09:26 AM
Nick@HSW's Avatar
Yes start with the recommended jetting first.
Nick
