can i use a 150shot with my 4.11 gears?
Old 12-24-2003, 10:28 AM
mike c.'s Avatar
Default can i use a 150shot with my 4.11 gears?
i have a head and camed m6 w/4.11's. i am ordering the new nos fuel rail fogger from speed inc,how will my car act on a 150 shot? my tires are 305/40/16 they sit a good inch taller then stock. don't worry,i have the 12bolt and all the other goodies to take the punishment. THANKS,mike c.
Old 12-24-2003, 08:03 PM
strokedls1's Avatar
Those tires won't stick. I know a lot of people with 315 tire that don't stick. The 150 is doable but I wouldn't count on the engine holding up on the long term. Just make sure the fuel pressure is good.
Old 12-24-2003, 08:39 PM
n2o
n2o's Avatar
You will encounter hooking problems.
Old 12-24-2003, 10:59 PM
EVIL's Avatar
gear wise, you will be fine. traction wise, its gonna be spin city.
Old 12-25-2003, 12:53 AM
taqwache's Avatar
no problem, but just make sure that you let off before the rearend of the car trys to pass you up. if not you will end up in a ditch. once you get some slicks or et streets, your going to love it. also try not to get to close to the rev limiter or the air lid might blow off, this is very easy to do with 4.11s and a M6.
Old 12-25-2003, 05:48 AM
silverTA's Avatar
u need taller tires ,,get some 28,11,15
Old 12-25-2003, 02:21 PM
mike c.'s Avatar
i'm running m&h racemasters,i pull the fromt wheels off the ground,these tires hook hard. i also cut a best of a 1.59 60 foot. with et-streets i could only get a 1.68 best 60. the m&h tires are close to 27in tall.
Old 12-25-2003, 06:09 PM
mike c.'s Avatar
STROKEDLS1.-my motor better hold up for all the money spent on a FORGED rotating assembly.like i said,i have all the parts for the punishment!!!!!!!!!
Old 12-26-2003, 05:38 PM
EVIL's Avatar
27 inch qtp's work great! but with the 28's my car felt alot more stable.
Old 12-27-2003, 10:41 AM
mike c.'s Avatar
cool. looks like it's doable,as long as i've got the tires to handle it. i'm not going to spray out of the hole,just 2nd,3rd and 4th. THANKS GUYS.
