NOSzle system ? -- How much spray can it safely handle
After searching, it seems to have gotten mixxed reviews. I'm considering buying a used system locally, but don't know if it can safely handle a 250 shot. What about a 300? Any experiences would be appreciated.
I have an NX MAF kit now, but am looking to go bigger this season.
I would go with a plate or direct port setup! If your intent on never going past a 250 shot id say a hsw or n2o outlet plate setup would be nice. Direct port only for 300+ shots, jmo...
Edit* I just realized the system your talkin about is a direct port style setup lol.
hey, don't throw the NOS version of the NOSzle under the bus for NX's sh1tty copy of it. The center injector discharge area is basically shrowded from the annular discharge of the nitrous on the NOS version. Look at the picture I posted above. There's essentially a trumpet around the center bore that protrudes past the nitrous discharge ports, not to mention the nitrous discharges from the outer ring. Here's a better cut-away picture:
On the contrary, the NX version simply pipes nitrous and supplemental fuel at an angle across/into the center bore creating a siphon over the injector stream.
The NOS engineers did their homework, the slack off plagerizers at NX f'ed it up.
I've seen the same issues with the NOS kits. Some have great luck, some don't... That post was just the first one that came to mind as I know the parties involved.
The problem with these kits is that there is really NO reason to buy one over having a direct port plumbed into the intake.
+1 for direct port.
NOS327, man you've got your stuff wrong. If NOS is so technically advanced and has such badass engineers then why do they have such shitty bottle valve designs and solenoids? Not to mention most of their stuff is made in China.
Both versions with make it run rich, so you simply need to downsize the fuel jet. Regardless of the brand though, I wouldn't run over 200hp on one.
BTW NOS327, how many motors have you blown?
+1 for direct port.
I don't care to squabble with you on the internet. The solenoids are based on CNG solenoids just like every other production nitrous and fuel solenoid. Their bottle valves outperform the majority of the market medical based bottle valves. You are also most likely misinformed about the quantity of NOS brand parts made in China.
I've yet to "blow" a motor. No exaggeration, I put thousands of pounds of nitrous through 3 different combinations in my own cars, not to mention various builds with my brother and a hand full of other local guys. The only motor I've ever been associated with that got hurt was due to a solenoid failure with a plate kit on a car in Georgia.
As I said before, I don't care to squabble with you on the internet, but I'd like to see logical and factual data to back up your claims about what exactly makes the NOS brand solenoids and bottle valves inferior to other typical domestic parts. I'd also like to know specifically which of "most of their parts" are made in China, if you care to expand on your claims. PM me if you like, this guys' thread is not the place for you and I to discuss it.
