High idol issue after HSW 78mm palate install...HELP
Old 03-07-2010, 02:52 PM
kidcamaro98's Avatar
Default High idol issue after HSW 78mm palate install...HELP
when I first start my car on a cold start, it idles at 300rpm, then stalls...crank it, and it starts, idols around 500 then stalls...everytime, 3rd time is a charm but it takes a good 15 seconds bouncing from 400rpms to 900...then it will idol at 1500 and hang there...
then once its warm, I shut it off, and start it and it idols up to 2k, then slowly makes its way down to 1k then its good to go. It drives normal and idols normal after that initial start and it never did this until after my HSW plate install. It almost acts like there is a VAC leak, but once the car idols down, the idol is good and it doesnt bounce around...
do you guy think it could be my throttle blade needs to be adjusted now? I checked to make sure the throttle cable wasnt pulling on the TB butterfly a little, and thats not the issue. Any Idea's???
pic...
Old 03-07-2010, 03:03 PM
1995blacktattop's Avatar
have you been watching
too much lately?
Old 03-07-2010, 05:01 PM
too much lately?
did you just really post this nonsense of unhelpful info??
Old 03-07-2010, 05:18 PM
9 Second Club/Nitrous Mod
shortdog's Avatar
Sounds like you have a leak. There should be a gasket between the tb/plate and plate/intake. Also, make sure the bolts are tight and check to see if you accidentally damaged the gaskets during install.
Old 03-07-2010, 05:44 PM
SkullV's Avatar
No throttle cable extension necessary with a 1" thick plate?
Old 03-07-2010, 05:50 PM
jessesta's Avatar
It was funny!
Old 03-07-2010, 06:41 PM
The HSW kit comes with a throttle cable extension mount...so it already has it.
My gaskets are good on both sides...I double checked it today and made sure all bolts were tight.
also, I noticed that my TB butterfly is shut all the way, and I have the hole on the TB blade plugged....I had this problem before with it hard starting and wanting to stall and I just adjusted the butterfly by the adjustment screw enough for it to suck a little air.....I am 99.9% sure this is my problem again being as im a MS3 car and enough air on startup is critical.
Old 03-07-2010, 09:47 PM
silver69camaro's Avatar
Sounds like you were using the throttle stop adjustment to keep your idle decent w/ cam and when you installed the adapter plate it knocked off your adjustments. Did you do this or did someone that was tuning your car do it?
Old 03-07-2010, 09:49 PM
yes. i was browsing all the new posts and got a laugh out of the title
Old 03-08-2010, 07:59 AM
I did this. Its getting a new street tune/dyno tune from scratch april 17th so it should run MUCH better. Until then, I will adjust my throttle body again.
Old 03-08-2010, 10:32 AM
Nick@HSW's Avatar
I wouldn't recommend using the throttle stop to adjust your idle speed etc. You need to keep in mind that if things aren't functioning properly or set properly, adding additional go fast goodies is only going to compound issues. My advice would be stop messing with it and have a tuner adjust it properly to avoid anymore issues.
Nick
Old 03-08-2010, 12:55 PM
brokenfly's Avatar
put more slack in the cable from the adjustment point...even though hard to see,the cable is still tugging on the blade some...
Old 03-08-2010, 09:41 PM
I actually adjusted the screw a little today on the throttle body to adjust the butterfly and it solved the issue of starting hard/wanting to stall....
but on a hot start it idles up to 2k right away and 5 seconds later idols down to 1k...not sure what that issue is about...never did it before the plate install.
Old 03-09-2010, 05:15 AM
brokenfly's Avatar
i meant the slack adjuster for the cable itself,not the idle set screw...
Old 03-09-2010, 07:23 AM
slack adjuster? Didnt know we had one. Where is it? lol
Old 03-09-2010, 12:19 PM
Nick@HSW's Avatar
They are circled in red. Use the one going to the throttle body first.
Also any reason why you're running redundant solenoids?
Nick
Old 03-09-2010, 02:14 PM
Nick
sorry nick, Im new to this nitrous thing! Ask me anything about a turbo setup and I know my **** but not this stuff! lol
What do you mean by "redundant"??
Old 03-09-2010, 02:20 PM
camscam02's Avatar
You have two nitrous solenoids in series on your kit. He is asking the reasoning?
Old 03-09-2010, 02:32 PM
Nick@HSW's Avatar
Not a problem. That's why we're here.
I was asking why you're running two nitrous solenoids in series like Cam above asked. Looks like it was a dry kit at one point prior?
nick
Old 03-10-2010, 01:53 AM
LilJayV10's Avatar
It does? What does this creature look like?
