how many times can u purge a 10lb bottle
Old 04-06-2010, 05:43 PM
Restricted User
kalebm22's Avatar
Default how many times can u purge a 10lb bottle
about how many times can you purge a 4an 10lb bottle with a single purge before its empty? ik this is a dumb question but its addicting haha
Old 04-06-2010, 05:53 PM
BakaN20's Avatar
Get a co2 purge kit, you already have nitrous so you're not really faking the funk. I am sure you love purging to show off, so purge the co2, much cheaper and you won't waste any of your nitrous, lol.
Old 04-06-2010, 05:59 PM
Vader TA's Avatar
local guy here purged his whole bottle one night showing off....we waited til the end of the night to get a run, by then his bottle pressure was so low it was an easy win for our bolt on car
Old 04-06-2010, 06:06 PM
Ph.D. in HUBRIS
custm2500's Avatar
Well you figure a bottle is good for a minute of use down the strip. So you have a good amount of time to make a scene before you run your bottle too low.
Old 04-06-2010, 08:10 PM
Restricted User
kalebm22's Avatar
where can i get a co2 tannk filled? and how much is a kit?
Old 04-06-2010, 09:01 PM
BakaN20's Avatar
Any paintball shop can fill you. Check out our forum sponsors. They range from $100 to $350.
http://www.dynotunenitrous.com/store...?idproduct=120
http://www.dynotunenitrous.com/store...?idproduct=128
http://www.nitrousoutlet.com/catalog...=23&section=80
Also, if you look at the size of the jetts, the hole, they are fairly small compared to the purge tube outlet, so I would think that you would purge more than you would actually use in a shot.
Old 04-06-2010, 09:07 PM
02 BLK WS6's Avatar
Why would you want to purge a whole bottle? Sounds retarded, ricer, and wasteful to show off by purging an entire bottle of nitrous. Nitrous isn't intended to show off, it's intended to go faster.
Old 04-06-2010, 09:19 PM
ShiznityZ28's Avatar
this post should be deleted..... Makes real nitrous guys look like ricers.
Old 04-06-2010, 09:34 PM
Restricted User
kalebm22's Avatar
haha do wat ever you want with this post, ur not goin to hurt my feelings. i never said i was goin to purge an entire bottle. i just wondered how many times it could be purged before its to empty to use. i wont be using nitrous on the street but it is fun to scare little ricers on the street, then i refill it and use it at the track.
Old 04-06-2010, 09:55 PM
speedcrazy2's Avatar
How much does it cost to get a bottle like that filled with co2?
When I played paintball it was like $3 for a 20oz. tank
Honestly OP just get you a second nitrous bottle if you really think you cant contain yourself. lol!
Old 04-06-2010, 10:15 PM
Restricted User
kalebm22's Avatar
ya, im thinking that i will. i dont do it that often, but i dont make it to the track as often as what i would like either. how much is the goin rate for nitrous in your area?
Old 04-06-2010, 10:35 PM
itsslow98's Avatar
this must be the "how to make my car look like it belongs in the Fast and Furious" thread
Old 04-06-2010, 10:42 PM
SkullV's Avatar
Nitrous around me is $4.95 a pound! No way I would waste a bottle on the atmosphere!
Old 04-07-2010, 11:39 AM
Midnight02's Avatar
Just playing around on the street I usually get a good 10 - 12 "shots" (by no means is a "shot" a full run through the gears -- I usually only have a shot to run through a gear or two before I run into traffic or hit a speed that's inapproriate for the surroundings) out of a 10 lb bottle and I purge the line after I finish playing around.
I guess you could probably purge it 6 - 8 times and give a pretty good show.
Old 04-07-2010, 11:45 AM
Restricted User
kalebm22's Avatar
thanks for the info, so you think 6-8 times would empty the bottle? and is that long purges or short
Old 04-07-2010, 02:31 PM
BADMOON's Avatar
why dont you just fill the bottle up and hold the purge down and see
Make sure to video tape and post it in this forum.
Old 04-07-2010, 03:34 PM
david vericker's Avatar
Originally Posted by itsslow98
this must be the "how to make my car look like it belongs in the fast and furious" thread
And that's the truth!
Old 04-07-2010, 08:09 PM
Nick@HSW's Avatar
Being that I routinely waste nitrous on a daily basis...I'd put another vote in for the CO2 dummy systems.
Nick
Old 04-07-2010, 10:12 PM
Restricted User
kalebm22's Avatar
Nick
thanks for the advice nick, i just ordered a new kit from you guys last night. im goin to be needing a few more things so ill probly be givving you a call.
Old 04-07-2010, 10:22 PM
NOTFAST's Avatar
83 times
Quick Reply: how many times can u purge a 10lb bottle
