Plate kit suggestions NEED KIT THIS WEEK
Looking to get a kit on my buddies car THIS WEEK! Anyways, few questions out there as we do not know too much about nitrous kits.
Looking to spray 100 shot. Looking for something that will not require an additional dyno tune (is this possible?) I talked with HSW a while back when I was thinking about a kit for my car and they mentioned a dry plate with the interface could do exactly this....
So what would you guys suggest, why, and who can get us a COMPLETE kit with all gadgets by Wednesday?
Thanks!
-Jon
Thanks!
-Jon
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Right on, HSW suggested using the Interface to pull timing and a wet plate kit. How's this sound?
__________________
the Interface will be suffecient for 100 shot now. but if you got the Interface and wanted to go up to a bigger shot later, you would have to change your IAT Spark Advance Correction Table in the PCM. Which would require Tuning Software to change. Here is link to stock IAT Spark Advance Settings....http://www.harrisspeedworks.com/pict...ng-retard.html. Which shows that the Interface will only pull 3* of timing based on stock pcm program for LS1 motor. If you want to keep your options open in the future (and dont tune your own car) I would look into the Lingenfelter Timing Retard (pulls up to 15*) or the LS1 Timing Tuner (pulls up to 12*). just some FYI......
And Just My Opinion....but I like wet kits better than dry. I dont like depending on 8-10 year old Fuel Injectors to add the fuel for the nitrous. I like being able to adjust my fuel thru the simple swap of a fuel jet in a wet kit, and know my engine is getting adequate fuel with the nitrous. (I know distrbution is always debatable with Any kit other than Direct Port kits, not wanting to start a wet vs dry debate, guys!!! JMO).
I would got with the Nitrous outlet plate kit. I would call and talk to dave or chris. http://nitrousoutlet.com/catalog/cat...=14§ion=37
Thanks!
-Jon
Thanks!
-Jon
Let me know if you have any questions that need answered. Thanks!
Nick
