Can a FUEL CELL be used to feed a WET SHOT system????
I'm just curious because I'd rather not drive around with 100 0r 103 octane gas in my regular tank. I like the idea of having fuel cell (like the DP systems do) so I can just keep race gas in it and run around N/A with 93 octane.
Thanks
Thanks
Originally Posted by Vents
yup. several of us are doing just this. however it's not too ideal for shots over 250 or so. ya really need to go DP for that much.
So would that work for what I want? 150 dry can be with the 93 octane and then the 150 wet can be from the cell with 100 octane going through the nozzles?
Originally Posted by itchygomey98
Just keep in mind - if you run the cell out of fuel, then your wet shot just became dry!
Thats why I was wondering how much fuel would be needed in the cell. If its a full 1.5 gallons how many shots would that support?
The Bull
I can make a full 300 shot pass on my direct port and use a little under 1/3 gallon. My fuel cell is only about 2/3 of a gallon and there usually is enough to make 2 passes. However, I'm not a fan of meltdowns so I top it off after each run. On 1.5 gallons maybe 6 runs wouldn't be a problem at 150 on a DP. Not sure how that translates to a single wet nozzle though.
I'm sure that NX or NOS could tell you the average volume of fuel displaced through the orifice at X pressure, Z orifice size and Y duration.
Originally Posted by taqwache
i also ran a 1 gallon fuel cell and ran 4 complete runs using a 250 shot and still had some fuel in it.
If so, besides the tank, what do I need to buy in addition to the complete TNT F1 system?
I'm thinking just a fuel pump for that cell?????
Another benefit with the fuel cell is that it wont be drawing any fuel away from the rails. Supposedly this can be a problem with big shots. Ive thought usin a fuel cell just for that reason.
I'm just a newbie at its best. I'm thinking a cell, a pump, lines to the solenoid.
Is there any pics anywhere of this.
Thanks.
