ms4 cam and forged bottom end?? nitrous?
Old 10-04-2011, 09:46 AM
n20ls1cam's Avatar
Default ms4 cam and forged bottom end?? nitrous?
i have an ls1 with forged wiseco pistons and eagle h beam connecting rods but a stock crank, 243 heads that were milled and it is 11.5 to 1 compression, and a ms4 cam with a 112 lsa. the motor has about 5k on it. my question is, will my setup take well to nitrous? also how much do you think my bottom end can handle? i was thinking of spraying a 300 shot at it. thank you very much for your help!!
Old 10-04-2011, 12:54 PM
Cold Zero's Avatar
What pistons & rods do you have ? What piston rings ? Ring gap ?
Old 10-04-2011, 12:59 PM
n20ls1cam's Avatar
i have wiseco flat top pistons with -3.2cc reliefs, wiseco gfx rings, and forged eagle h beam rods. im not too sure on ring gap.
Old 10-04-2011, 02:37 PM
n2ols1cam's Avatar
also i have a aeromotive 340 fuel pump. will i be maxing out my pump with that big of a shot? and can i still run 93?
Old 10-04-2011, 03:08 PM
Johnnystock's Avatar
You should start with a small shot like a 75-100 and work your way up to 250-300... 300 is kinda too much IMO, unless youre racing. For the streets 175-225 sounds safer. I would do a 150 or 175 for the ease of it. I'm running a 150 and its a no brainer.
Old 10-04-2011, 03:29 PM
Sluggish's Avatar
I had a 150 dry with my ms4 on a stock bottom end and never had an issue, my car trapped 129 almost 130 on it @ 3600lbs. Put some NGK- BR7EF plugs in it and at least a 200 shot on it.
Old 10-04-2011, 03:40 PM
n2ols1cam's Avatar
thanks guys! i have a 125 shot on there right now with b8efs and i have a nitrous outlet plate that i am going to install and i wanted to get at least a 200 shot on it. will i max out my fuel pump? also can i run 93 with a 200-300 shot?
Old 10-04-2011, 05:21 PM
1972camarols1's Avatar
300 is a bit much to just jump into... Work ur way up.
Old 10-04-2011, 07:28 PM
n2ols1cam's Avatar
ok i will. if i wanted to spray that a 250-300 could my bottom end handle that? also will my pump be able to keep up? when i was on a stock bottom end i sprayed a 175 with a stand alone but i sold the stand alone to get the fuel pump i have now. i am not really new to nitrous, i just want to know if my setup now will take as well to nitrous as my set up did when i had a ms3 cam.
Old 10-04-2011, 07:48 PM
kidcamaro98's Avatar
subscribing.
if your ls1 still a stock 346? I am looking to forge mine for nitrous this winter as well. ms3 cam here.
Old 10-04-2011, 09:20 PM
n2ols1cam's Avatar
Originally Posted by kidcamaro98
subscribing.
no i have forged pistons and rods. i had a ms3 when the bottom end was stock and it took very well to spray but i have a ms4 now and i mainly want to know if the ms4 will love spray.
Old 10-04-2011, 10:45 PM
89pigeontoe's Avatar
I would say your getting pretty close to on the fuel pump @ 300. Anything 175 up I would prolly run a race gas mix.
Old 10-04-2011, 11:11 PM
n2ols1cam's Avatar
Ok, thank you for your help. What would be the mix ratio?
Old 10-05-2011, 07:45 AM
Cold Zero's Avatar
With your piston/rings/rods you will be fine spraying 250 shot with the right tune
you shouldn't just through that big jetting into your plate from the 1st time .. start with 100 shot ,, step then to 150 shot ,, and make your way up watching the AFR, Timing, Nitrous & Fuel pressure on each step
A stand alone fuel system is very recommended on bigger shots, you can run C16 in the standalone for nitrous and running N/A on 93 pump gas in your stock tank
Old 10-05-2011, 09:38 AM
n2ols1cam's Avatar
With your piston/rings/rods you will be fine spraying 250 shot with the write tune
ok thanks. i will work my way up im just testing my boundaries with the bottom end i have. what would be the biggest shot i can get away with on pump 93? i really wanted to keep it on pump gas and stay away from a stand alone.
Old 10-05-2011, 10:24 AM
Cold Zero's Avatar
Personally I have done 150 & 175 shots on 93 pump gas but above that I used c16 in stand alone fuel cell
Come on man, your setup with 250 shot will make over 650 rwhp and over 700 rwtq ! .. that power level on LS1 is really worth pulling the trigger on standalone
What plugs you gonna use ?
Old 10-05-2011, 10:45 AM
n2ols1cam's Avatar
yeah youre right but i street race the car a lot and when someone sees a stand alone it scares them off. lol
right now i have a set of b8efs in the car. what do you recommend?
Old 10-05-2011, 03:17 PM
Mr. Hyde's Avatar
Stock bottom end with MS4 here....250 shot (Dave's plate), 8's for the plugs and a standalone running C16 (most of the time)...it's not a daily driver but so far it's held up. On a 200 shot before standalone it made 653/789 on a dynapak, FYI.
Old 10-05-2011, 03:51 PM
n2ols1cam's Avatar
thank you for the info. i have Dave's plate as well. would i be able to run 100 octane and a 250 shot? i really dont want to run a stand alone.
Old 10-05-2011, 04:52 PM
Id say thats more realistic, just be conservative on timing.
Quick Reply: ms4 cam and forged bottom end?? nitrous?
