150 shot from fuel rail???
I have an a1000 with number 8 feed and 6 return and fast billet fuel rails
Was wondering if I can run a 150 shot off the fuel rail and still be safe on a h/c/I 346
FWIW - I spray 300 off stock fuel rails with a single 255 and hotwire kit. Not recommended but it works so far. With what you have I would feel comfortable spraying much more than 150.
If the regulator is before the rail wouldn't pressure drop on the rail when nitrous grabs fuel off the end? Dumb it down for me...
Maybe no regulator at all??
Is that an in-tank pump? How do you have it setup to regulate pressure in the rail and off the rail? Does that make sense?
Hey sarge, stock replacement in tank racetronix 255 with howire kit. that's all...
I use the frps that came with my nitrous kit, it is preset at 35psi.
