Thinking of Spraying c5Z
Heres the current build:
347ci LS6:
Kings Cam bearings, bored 3.905" done by TPIS
Stock Ls6 Crank, polished/balanced
Diamond LW Forged flattop Street/Strip pistons #11502 (404 grams each) w/ floating pins. -2cc Valve Reliefs
Probe LW Forged I-beam Rods 6.125" (600grams each) w/ ARP bolts
Clevite Coated "H" Main bearings
ACL hi-perf/race rod bearings
Total seal Rings (conventional gap) 1.5mm/1.5mm/3mm / Moly Steel Top Ring / Ductile Iron 2nd Ring Filed to .016 Top ring and .018 2nd ring
C6 oil pan
TSP 233/239 .598 .603 113LSA cam
LS2 Timing Chain
Ported Ls6 oil pump Shimed .060"
160* T stat
PRC .650 Dual valve springs
Manley hardened pushrods 7.400"
Ls7 Lifters
Stock 1.7 Rockers w/ Comp Upgrade Trunions
ARP head bolts
Ported 243's flowed 317cfm intake/210 cfm exhaust, 228 cc intake volume.
GM MLS Headgasket
Around 10:7:1 SCR
SpinMonster Port Matched Fast 92mm Intake
Ported 90mm T/b
Driveline:
C6Z 30 Spline Mainshat MN12
C6Z Clutch Packs
ECS Diff/Trans Brace
3.91 gears
300M Left side shaft
C6Z right side shaft
Billet Pinon Support
Centerforce DF 12" Clutch
Stock LS6 Flywheel w/ ARP bolts
LPE 2-Step with Timing control.
Fuel System:
Stock Pump (Have a walbro 255lph just havent installed)
SVO 30lb inj. (Have some Lucas 42lb injectors but havent installed)
What kit would most recommend??
Dry/Wet???
What Controllers?? (MicroEdge, Edelbrock, Nitrous Outlet, etc)
How big of a Shot?? (Look to barely crack the 600whp)
Bottle heater/NANO??
347ci LS6:
C6 oil pan
LS2 Timing Chain
160* T stat
Ls7 Lifters
ARP head bolts
GM MLS Headgasket
Around 10:7:1 SCR
Ported 90mm T/b
Driveline:
C6Z Clutch Packs
3.91 gears
Fuel System:
Dry/Wet???
Guest
Posts: n/a
You are difinitely going to need to upgrade the pump to the 255 you have and might also have to add a hotwire harness to pair with the pump in order to spray the car. A walbro 255 by itself is good to newhere around 550-600rwhp in most cases.
For the system we make a very nice Vehicle Specific Plate setup
http://www.nitrousoutlet.com/catalog...4&product=3946
For the controller I would suggest the NOS Mini Progressive which is a nice unit. [ We are currently going through a re-design on our switch's and will be a couple of months before they are ready for sale ]
http://www.nitrousoutlet.com/catalog...2&product=4446
Depending on your current power level you should be able to hit the 600+RWHP mark with a 150-175hp shot.
On the heater/ nano question you could do either... Both work good but the Nano will give you a 100% constant bottle pressure unitl the bottle is empty where the bottle heater would have a pressure drop as you made passes.
Thank Chris. Im currently @ around 470whp. Think I should sink some coins into a 340LPH pump then?? Or would I be better doing a stand alone fuel system. I have deleted the washer fluid tank so I have room to put it there.
No matter wet or dry you will need to upgrade the fuel system. The racetronix system will usually support about 650 rear wheel hp. Even with the racetronix you may be playing with the border line of what it will support, so a desicated may be something to look into.
I personally am not a fan of doing a dry system with teh factory PCM. However I have installed and tuned many of them. If I were to do a dry system I would do it using the EFI Live custom operating system to add the fueling and remove the timming. It is by far the most reliable and best way of doing it.
Dave
Dave
First off, nice car & What a build! I have a much more tame (mostly stock) 01 QS Z06....
Don't even think about spraying a dry shot with those 30lb injectors on the motor. Get the 42lbers installed ASAP.
Nitro Dave is the nitrous man, so believe what he says, but I gotta throw my $0.02 in and say that a proficient tuner could use HP Tuners to handle the tuning.
Ive got HPTuners all of my own stuff. I'm already about 87% duty Cycle @ WOT on the SVO 30lb injectors (Really 36lbs @ GM 58psi). So I will be installing the Lucas 42lb injectors before the spray. Still cant Decide Wet/Dry
nitrous all the time unless of course HP Tuners has done something like EFI Live's COS5 Nitrous tuning setup. This means you are running around rich with less than optimal spark. With wet, the worse case is you have reduced spark, but have a good mixture when not on the spray. One good thing about dry is you don't have to worry about a failure of a fuel solenoid, thus melt down.
- upgrade the fuel system.
- get the nitrous outlet plate wet system.
Doesn't the HSW A/F interface linked with the timing twisted I'm currently using as a simple two step bridge the gap between HPTuners vs. EFI live in the tuning??
http://www.harrisspeedworks.com/prod...&cat=57&page=1
Maybe I'm misunderstanding this product a litte?? (Thats why I'm asking your guys opinon!!)
As for the fuel system what should be suffice @ 600-620whp car N20 car?? 42lb inj + Walbro 255lph pump??
BACK FROM THE DEAD!!!
Finally ordered the N2O kit...
Installed an LPE 255lph Pump kit also
Nitrous System contents:
Corvette Stand-Alone Fuel System w/ pump, regulator, 53psi etc.. From Nitrous Outlet
Nitro Daves 90mm Wet Plate
Jets 50,100,150,200
Nitro Daves Noids
Nitro Daves Billet Dual Heated Bottle Bracket
2 Brand X 10lb bottles
Y connector
Nitro Daves Progressive Controller w/ Window Switch
16ft 4AN Feed Line
Relays
Purge Kit
Might be adding a FPSS on the Standalone fuel cell for the added comfort...
Sooo with this engine Combo how much should I spray???
125/150/175/200shot???
Jets 50,100,150,200
Nitro Daves Noids
Y connector
16ft 4AN Feed Line
Relays
Purge Kit
