TNT Power ring for 90 mm TB?
Cool, that's good to know. I've been avoiding getting a larger throttle body because I didn't think the power ring had enough material on it to machine it to fit a 90mm throttle body.
Originally Posted by LS1 Power Plant
My brother was able to grind the crap out of mine to fit (and open up) my 90 mm TPIS throttle body. Took a while, but it is possible...
So I could have someone competent grind on my TNT F1 ring so it will fit. Or is it something I could do?
Originally Posted by GM Muscle
I would bring the ring and throttle body to a machine shop. They could make it fit perfect. Although, if your good with a grinder or a dremel I'm sure you could make it work.
Or do you have to have a custom or sheetmetal intake?
I'm not sure what kind of gains 427/436 owners are seeing with the 90mm throttlebody/LS6 set up, the gains might not be worth the investment. If you had the extra cash, a 90mm FAST intake and matching throttle body would probrably be well worth the money with your set up.
I don't think any vendor has the 90mm FAST throttlebody yet but, LG Motorsports is making there own. I think Thunder Racing and a couple other vendors have the 90mm FAST intake in stock. It would be over $1000 investment for both but, LGM made 503rwhp on a heads and cam car with this setup.
