3 passes on 150 shot and spin rob bearing i think
Old 02-27-2012, 09:36 PM
loosews6's Avatar
Default 3 passes on 150 shot and spin rob bearing i think
well i finally got my tnt f2 kit hook up and pill it for 150 shot had 93 pump gas in it timing was 23-25* ...only run 1/8th made three passes and i guess it spin a rod bearing or cracked the flywheel because it knocking ....had good oil pressure 60-70...u guy thinkg it's a bearing or my buddy said he cracked his stock flywheel also.... but it was hooking for a stock car no cam just 3400 rev max converter, ls6 intake,long tubes, 3" all the way out, 9" rear with 4:11 gears, adjustable rear,shocks,phb,lcr's... times was
SPRAYING OUT THE HOLE TOO...
60ft-1.50
330ft-4.69
et@594ft-6.80
1/8et-7.34
1/8th mph-92.59
Old 02-28-2012, 07:55 AM
87silverbullet's Avatar
Spin Rob, is that a rock band or something?
Old 02-28-2012, 12:57 PM
Captain Double Post
BOBS99SS's Avatar
Did check it out? Check oil,cut filter etc. What does the oil pressure read now?
Old 02-28-2012, 08:35 PM
loosews6's Avatar
When u first start it in morning 75 to 80lbs or oil....
Old 02-28-2012, 08:57 PM
Wicked94z28's Avatar
I broke the bellhousing on my tranny and when the tranny fell it bent the flywheel and it sounded like it was knocking so hopefully that's your problem!
Old 02-28-2012, 11:11 PM
Nitro Dave's Nitrous Outlet's Avatar
Man, That bites! Did you take a look and see if it was the motor or not?
Dave
Old 02-29-2012, 06:04 AM
loosews6's Avatar
Dave
going to today when i get off work...
Old 02-29-2012, 06:51 AM
autogeek23's Avatar
thats some serious flex off the line. good luck with your findings
Old 03-02-2012, 03:49 PM
loosews6's Avatar
well looks like i spun a bearing.....oh well now i can finish my 408 stroker the shortblock is done
Old 03-02-2012, 05:08 PM
dville_gt's Avatar
get an anti-roll bar for gods sake, that thing is types of twisted up
Old 03-02-2012, 05:35 PM
green96ta's Avatar
Just from my experience, most of the people I know; including myself run about 18 or 19 degrees of timing on a 150 hit. 23 degrees sure seems like A LOT on a 150 hit...
Old 03-03-2012, 01:07 AM
transam69230's Avatar
You got sub frame connectors on that thing?!
Old 03-03-2012, 01:20 AM
SexyTransAm's Avatar
nasty pics man
Old 03-03-2012, 01:40 AM
itsslow98's Avatar
That pic is horrible, that chassis is begging for mercy.
Old 03-03-2012, 07:59 AM
That all depends on what his total timing was. If it was 29* he would of been right on it with 6* pulled putting him at 23*
My car for example had a total timing of 28* and I pulled it down to 24* on a 100 shot.
Old 03-03-2012, 10:34 PM
Fbodyjunkie06's Avatar
On 93 pump gas for his 3rd pass ever on nitrous, that's too much timing.
Old 03-04-2012, 12:52 AM
01SOMZ28's Avatar
I used to spray my car with 150 and stock timing alllllll the time back when i was a noob and didn't know any better. Nothing ever happened, lucky?
Old 03-04-2012, 07:50 AM
Old Geezer's Avatar
Lightbulb Yep!
Old 03-04-2012, 02:00 PM
Not really and he was only running 1/8 mile also. Without knowing his total timing you can't say he wasn't pulling enough. Every combo is different. My buddy's t/a ran on 23* on a 150 shot on pump 93 thru the 1/4. Every combo is different.
Old 03-04-2012, 04:16 PM
Captain Double Post
BOBS99SS's Avatar
at least you got some cool pics out of it, and at least youknow you have some suspension work to do after looking at them lol
Quick Reply: 3 passes on 150 shot and spin rob bearing i think
