Harris plate with nx jets?
Old 03-08-2012, 11:03 AM
MIG74's Avatar
Default Harris plate with nx jets?
Hey guys nitrous newb here. Can I use NX jets on a HARRIS 78mm plate? I know the fuel line is shorter( thx Nitro Dave). Just want to make sure the jets will work. Piecing together a kit w Iceman solenoids and HSW PLATE. Thanks
Old 03-08-2012, 11:41 AM
camscam02's Avatar
yes they are the same jets
Old 03-08-2012, 11:55 AM
MIG74's Avatar
Thx. I have the article with your car in GMHTP. Badass... Appreciate the quick reply.
Old 03-08-2012, 12:11 PM
camscam02's Avatar
no problem, and thank you very much
Old 03-14-2012, 12:00 AM
Nitro Dave's Nitrous Outlet's Avatar
Some of the earlier Harris plates used the NOS Style jets. Since cam had a harris plate and he is saying his used NX style jets they may have used two different jet fittings as well. If the NX jets you have do not fit in the fittings, remove the fittings from the plate and drill them out using a #10 drill bit. Then screw the fittings back into the plate. Then the NX jets you have will work.
Dave
Old 03-14-2012, 03:51 PM
MIG74's Avatar
As always, thanks again Dave
Old 03-14-2012, 06:08 PM
Anytime.
Old 03-21-2012, 03:16 AM
kidcamaro98's Avatar
subscribed
