TNT F1 question
TNT F1 question
I'm considering getting a FAST 102 intake/TB for my T/A. When I bought the car, it already had a TNT F1 wet kit installed. Now that I'm looking into getting the larger TB, I realize that the ring which holds the nozzles was only built for the stock 78mm TB.
What are my options in getting a larger ring? I know there are 90mm rings floating around, but seem kinda rare to come by. Is a 102mm ring something that I'd have to have custom made?
If I did go with a plate conversion kit, is this the kit I would need?
http://www.nitrousexpress.com/produc...ls.php?id=1583
If you still have the mass air meter we have a bracket that bolts to it and holds the solenoids. Then you would just need nozzle adapters to lock the nozzles onto the air bellow. I set up a dual nozzle car like this years ago and it looked really clean.
If you decided to go with a plate this is the one you need.
http://www.nitrousoutlet.com/catalog...7&product=4111
You would also need to convert your solenoid fittings to straight fittings and convert the nitrous hose from the nitrous solenoid to the plate to our race hose.
Dave
Dave
Thanks for your help guys, I think I'm going to try to create something with some spare aluminum fittings I have laying around.
Junkie, give me a shout if you find yourself up in the Raleigh area. I'd like to see that silver car sometime!
