Vid from last night at Midnight drags EXTREME STREET 9.43 with the TA
Here is a vid from the my TRANS AM extreme street class car ran its best so far to date 3760lb car the pig TA went 9.43 pulled the tires passed the tree and letting off coasting. This was a text pass the AF was a 10.9 on this run it has more left in it so will update next time I go to the track. Thanks to DAVE@ N20 outlet for helping with some tweaks to the car.
http://youtu.be/xzV9jkTMjpE
Shes getting there is on low timing and #10 plug. Going out next friday to pull plugs and tweak the tune. Hoping to get our camaro out this next couple weeks and make some pulls on the stock short block.
Our cars look almost identicle. Mine is a even bigger pig! Looks like they leave about the same as well... what kind of na times do you run? im just trying to determine where my 427 should be on the bottle. Do you have a fogger or a plate? how much totoal?
Awesome car btw, gives me modivation to get mine ready!
I run a Nitrous Outlet D.P with. Fast 90. Car on 24 degrees of timing NA ran a 10.65 w a 1.70 60ft the nitrous stall kills the NA times. I really haven't up the timing and played w the NA times I'm sure it would run faster.
Thanks Wes at Show me Speed If you guys need parts or suspension mods pm Wes At show me speed competitive in pricing great customer service.
All my Nitrous stuff and the set up is from Nitrous Outlet.
Has MT et drags 10.5x15. Motor is a 408 with patriot stage 3 heads reworked with custom cam, head stud, main stud,caddy lifters, yellaterra rockers, compression around 12-8 with kooks race headers, Car has stock K member A arms full interior, factory stereo ,air bags, console.
Suspension it has QA1s all around 315lb springs in the front, Umi torque arm, bmr control arms, Moser 12 bolt. Car has more in it just playing safe. I will probally replant this motor in the stock camaro we are building next year I would say.
