nitrous shot
nitrous shot
2part question what is the largest shot of Nitrous I can go on stock injectors
also I'm using a single nozel is it worth switching from that to a plate system if so I'm considering going to a 150 shot and a nano kit is the money worth the results ?
Posted from LS1Tech.com App for Android
Give us a little information on what you have. Is you system wet or dry?? Type of car, and power its making.
I'm using a wet shot single nozel brand x I already have a larger after market fuel pump my power is 330 on motor 440 on spray nothing big I just can't stand tuners so I put them down
it seems that you are going to be good with your fuel pump if it has been upgraded. The injectors you will not have to worry about since your fuel is going to be supplied by the fuel solenoid.
Nano is a great way to be consistent. It will keep your bottle pressure where you want it better than a heater alone.
150 will add a good bit more hp but don't expect it to be a overwhelming feeling. You are definitely going to notice the difference between 100 and 150.
