Quality Solenoids
Quality Solenoids
Currently who is making some of the best solenoids? From a technological standpoint, it looks like NX's solenoids design is pretty good although not as simple as others. Like always, the more moving parts, the more opportunity to break or fail. Anyone have any experience?
Nitrous Express & Nitrous Outlet get my vote When I got the 2 kits Ive got now One had a NOS purge, I had a Harris purge from a deal. The one kits a mainline the other has Iceman noids. Bout all of em are the same except for packaging / outter appearance IF you make a noid to complex/technical itll fail Thats my 2 cents Im sure others will add their take on it. The area you want/need technology is timing controlers & single or dual stage window switches. IF you use a progressive controller itll eat noids if theyre not a Quality piece
is related to the noids ability to keep the solenoid open under use and maybe better for use w/progressive units.
Believe it or not there is a science behind building a quality solenoid. I will not go into specifics comparing our solenoid to the competition but I can honestly say I would not build our solenoids any other way than the way we build them.
What a lot of people don't realize is that we custom spec solenoids for custom applications as well. We offer a lot more than what is on our web site.
Dave
Dave
As with anything you can use cheaper materials and cheaper machining techniques to lower the cost of a final product.
A company that understands flow design, reliability, and quality can design a product to perform in the manner that they feel is best to work in conjunction with there product line in the real world race environment.
On many of our custom direct ports and custom systems we spec out different solenoids. We do this because in many cases a different solenoid may be required to perform better in that environment.
Our solenoids are built using what we feel was the best way. Not what kept the price down so we can make more profit margin.
Dave
Dave
Dave
Dave
Guest
Posts: n/a
All of our solenoids that are made are appropriate for use with a progressive controller regardless of custom or off the shelf and the Nano has nothing to do with the specing of the noids but does have a lot to do with the jetting of the kit.
