Stand alone fuel pressure?
Old 09-19-2012, 06:50 AM
Footlead's Avatar
Default Stand alone fuel pressure?
02 SS Camaro LS1 EFI. I want to put a stand alone fuel system on my car so how much fuel pressure do I need to the fuel solenoid. I am coming off the fuel rail now @ 50 plus psi. When I go to the stand alone will a Holley Blue pump work or do I need a high pressure pump? What pressure is required?
Thanks
Old 09-19-2012, 09:08 AM
fergymoto's Avatar
That depends on the fuel pressure specified in the baseline tune up you received with your nitrous system. I would go with whatever starting point they give.
Old 09-19-2012, 09:41 AM
Neal@NitrousOutlet's Avatar
Since the blue pump is low pressure i would get a low pressure tune on the dedicated. 7-10 psi is good median so that you can drop or raise the fuel pressure to get your tune dialed in.
What kind of direct port do you have?
Old 09-19-2012, 10:35 AM
SargeZ06's Avatar
Neal
I also am going to switch from my rail to a Holley Blue and Stand Alone. My only concern is how well the Holley will atomize the fuel coming out of the plate. At a higher pressure I would guess that it atomizes better?
Does anyone know what the regulator that comes with the Holley Blue is pre-set to?
Thank
Sarge
Old 09-19-2012, 10:45 AM
Originally Posted by SargeZ06
Neal
Thank
Sarge
I'm not sure i think maybe 10psi. Someone else might need to chime in on that.
Your going to be fine on atomization as long as you change out your fuel jetting to the appropriate jetting. We have plenty of customers running the plate on low pressure dedicated fuel systems.
Old 09-19-2012, 06:41 PM
Footlead's Avatar
I have a HSW 78 mm plate. I am getting gas from the rail at the end and figured it would be smarter to leave that fuel system alone for engine and run a stand alone for the fuel solenoid and put 104 unleaded into it. the Holley blue will not put out as much pressure as the stock tank pump. Does that matter or not. Do I need a high pressure pump to flow the fuel to the solenoid or the holley blue and @ what pressure?? The high pressure is for the injectors anyway so what would be the deal on the fuel solenoid??
Old 09-19-2012, 06:44 PM
Footlead's Avatar
I can set the regulator to what ever pressure I need but I do not know the max pressure of a holley blue. The HSW plate im sure is built to flow a certain amount of fuel @ a certain amount of pressure with a certain jet. I need to be educated here. Can I run a stand alone on a EFI Plate kit with a Holley blue or is the high pressure pump a must in this application??
Old 09-19-2012, 07:04 PM
Randy WS6's Avatar
I run the Holley blue pump with a low pressure standalone system, i run 9psi. ,but mine is a direct port system 8 nozzles.the atomize has a lot to do with the type of fogger nozzle you will be using. The nitrous pressure help brake the fuel up and carries it to the runners.
Old 09-19-2012, 07:06 PM
Randy WS6's Avatar
You need a jet chart for your system
Old 09-19-2012, 07:43 PM
Footlead's Avatar
Harris Speed Works HSW is out of Business now. The kit I have is 78 MM wetplate kit adjustable from 75-150. I have the jets 75hp= n2o=.044 fuel=.024 100hp=n2o=.052 fuel=.028,,,,,,,125hp= n20=.057 fuel=.031,,,,,150hp=n20=.062 fuel=.035. The question is can I run these jets in the HSW plate with a holley blue on the fuel solenoid @ 9-10 psi?? or whatever pressure or do I need to buy the Nitrous Outlet stand alone with the high pressure pump in it with the regulator. $100.00 cuz I already have most of the parts for Holley blue system or $600.00 for the Nitrous outlet very nice system. Opinions and advice please chime in.
Old 09-19-2012, 08:15 PM
SargeZ06's Avatar
Those jets for fuel seem to be for stock GM fuel pump around 58psi. You can't run those with the holley if they are. You need bigger fuel jets.
Old 09-19-2012, 08:27 PM
Footlead's Avatar
I am pretty sure they are for the stock GM fuel pump running directly off the rail.
Old 09-19-2012, 08:39 PM
Footlead's Avatar
Hey Neal @ Nitrous Outlet...Is your stand alone kit in the Last days of summer sale??
Old 09-20-2012, 07:38 AM
THADD's Avatar
I have a low pressure standalone kit with a Holley blue. Fuel pressure is set around 6-6.5 psi. I am using this for Wilson plate kit. I have a 9 spread on my jets.......82n and a 73f.
Old 09-20-2012, 09:59 AM
Sales@Tick's Avatar
The main benefit with a low pressure system versus a high pressure system is with the low pressure system you have much more room to fine tune the amount of fuel being used as the pressure is lower and each change in jet will be a finer more minute adjustment.
With high pressure it might come to a point where you go down a jet size and it's too little fuel and it's too lean and you go back up in jet and it's too much and makes it too rich. With low pressure this wouldn't happen because you have a more finite adjustment.
We had this problem on our shop car on a 104n jet we were either too rich or too lean with just a .01 change in jet size on 58psi. To alleviate this we went to a low pressure set-up with a double crossbar plate. The low pressure should allow us more finite adjustments when needed.
Old 09-20-2012, 10:41 AM
No it excludes custom built items and labor.
Old 09-20-2012, 11:08 AM
Burrhos's Avatar
Low pressure systems also benefit from using much larger fuel jets. Larger fuel jets=less chance for trash to clog
Old 09-20-2012, 12:06 PM
Footlead's Avatar
Ok then what jet should I use on the 100 shot or 125 shot or 150 shot. Fuel jet?? @ Neal. That was the wrong answer! Lol
Old 09-20-2012, 12:08 PM
Burrhos's Avatar
The jet charts are just recommended starting points. You need to tune the car with a given jet spread and look at plugs and/or log the fueling with a wideband.
I run mine at 12.0 air fuel with a 52N/32F but your results may vary. I'm pulling from the rail on an already taxed fuel system so I put in a bigger fuel pill to help get the necessary fuel requirements for my shot. My standalone cell goes in next week and then I won't have to worry about it
Old 09-20-2012, 12:36 PM
SargeZ06's Avatar
Thanks Martin, THADD and Burrhos. I feel much better going with the low pressure now.
Quick Reply: Stand alone fuel pressure?
