NX fuel line ?'s
NX fuel line ?'s
Picked up a used NX single nozzle kit with the lightning solenoids, and had a quick question. I was going to mock up the system tonight and noticed that my fuel feed line is alot larger than the feed from the noid to the nozzle. It also has larger fittings than what my schrader valve has, one end is a 90 and the other is a straight. Anybody got any ideas as to wether this is how they come nowadays, do I need some kind of adapter, or just switch the whole line out for a smaller one? I used to have an old NX kit and dont remember having to buy any adapters for the fuel rail, but that was about 10yrs ago, so things couldve changed lol! Thanks in advance...
No, I got it used. The lines from the solenoids to the nozzle are of equal length and diameter, but the feed line from fuel rail to solenoind is larger than the others, and is WAY larger than the rail threads, it also has a built in 90dg on one end..
Do you have an adapter on your rail? Looks like a black fitting screwed onto your rail. Also my fuel line is about 18-20" long where on your setup it looks to be maybe 6" from rail to solenoid??
yes i have an adapter on my fuel rail. The fuel line going from the rail to the solenoid is shorter but i had that made when i had the kit on my old setup. I just didnt like all the excess line. That shouldnt matter in length size.
I also shorten my nitrous line going from the solenoid to the nozzle which i shouldnt have done. Those need to be the same length or close to it.
