Average price for nitrous install..?
I have a nitrous outlet plate kit that I want to have installed professionally. I'm running a progressive controller, as well as a timing controller. The timing controller is used...and the wiring is pretty ratty. I got a quote yesterday from my tuner for around 800. It seems high, what do you guys think?
and 1600 for 150hp sounds crazy to me man you could prolly go turbo for that money (if you did everything yourself). i picked up a zex race efi kit in the forums for $200 with a purge and -6 feed line. it did come with a nozzle but you could find a nitrous outlet plate for like 100 bux or so.
what's "professionally"? for $800 I'd want them to run all the wiring in the OEM loom, not add more, use an OEM fuse box, not drill any holes to mount the controllers, use bad *** brackets not already provided, clean bottle and feed line install (not just zip-tied to the fuel lines or something lame), etc. i'd say take your time and do it yourself
i say do it yourself.. my 3 hours included making some mounting brackets out of some 2x4 construction joiner thingys and painting them black lol. the wiring is so basic with very little research you could have it figured out no problem. or have your professional do the wiring it shouldnt take more than an hour..
There is no way you can install a complete kit, progressive controller, and timing controller let alone a used one in 3 hours with out it looking like one of those timed engine swap challenges. If it was all new I would quote 9-12 hours.
I cant even count how many cars we have seen over the years with horrific wiring and or installs and they wonder why they have issues all the time. A few were so bad we tuned down tuning the cars over the quality of the install.
Took way over 3 hrs and definitely more than 8 for me to install myself in a 2010 Camaro 2SS. Nitrous Outlet plate, progressive, LNC2000, bottle opener, heater, fuel hose upgrade, console switches, blow down tube, purge, no holes drilled, used factory wire loom as much as possible.
Always do it yourself. I don't have much respect for people that say "Oh, I had so and so build this or that for me." Where else can the conversation go from there? "So.... is there a warranty?"
some people have careers and have limited time my man and if money isnt an issue, then what does it matter?
And I like to save money and do it myself(despite the fact that I'm a 'career' man).
