Need help Running nitrous line
Old 07-07-2013, 09:38 PM
Joemac5959's Avatar
Default Need help Running nitrous line
I have a spare tire mount for my bottle. I was wonder what the best route for the nitrous line is. If anyone had some good suggestion that would be great.
Joemac5959's Avatar
I have a 99 trans am
Old 07-08-2013, 11:11 AM
87silverbullet's Avatar
Just drill a hole in the wheel well and run it under the car to the front.
Old 07-08-2013, 04:28 PM
Joemac5959's Avatar
I didn't know if there was a certain route people took with the line.
Old 07-08-2013, 04:35 PM
Brett H's Avatar
I have my bottle in the spare tire well and ran the line inside the car under the carpet and out a grommet hole on the passenger side under the dash. You can pull your pcm from under the hood to help with feeding the line thru.
Old 07-08-2013, 09:34 PM
JDEP162's Avatar
spare tire wll, drilled a jole in the side of it near bottles neck, ran behind wheel well, down along frame rail then followed fuel line to front. i have some pics if op wants
Old 07-09-2013, 07:45 AM
MFJ
MFJ's Avatar
I ran mine behind the plastic trim panels then out the grommet under the passenger back seat. From there I ran it behind the heat shields (which I drilled small holes and wire tied it to keep it from moving) all the way to the firewall and up to the solenoid.
But, through the firewall grommet below the computer would be pretty easy to do. I have additional wiring there for the n20 so that's why I went under the car.
I have since moved my bottle to the trans tunnel hump and didn't have to reroute my nitrous line.
Old 07-11-2013, 02:38 PM
Joemac5959's Avatar
Pics would be nice if you didn't mind.
Old 07-14-2013, 02:00 AM
JDEP162's Avatar
ok bud, ima post em soon as i get back on the laptop, on phone now.
Old 07-14-2013, 02:24 AM
JDEP162's Avatar
trey throwing these pics up for ya, not a super clean install, but functional
Attached Thumbnails Need help Running nitrous line-more-updates-055.jpg   Need help Running nitrous line-more-updates-057.jpg   Need help Running nitrous line-more-updates-056.jpg
Old 07-14-2013, 02:25 AM
JDEP162's Avatar
here some more, the one from under engine, the n20 line is the fuel hose wrapped around it with zip ties around it. protects line from heat and stuff.
Old 07-17-2013, 05:54 PM
Tstone's Avatar
Default I'm puzzled.....
I like the way you ran those lines
Tstone's Avatar
Cool pics
Old 07-17-2013, 08:34 PM
JDEP162's Avatar
thanks, aint the prettiest, but it works. and its protected pretty well.
Old 07-22-2013, 10:25 PM
Joemac5959's Avatar
Thanks for pictures. It helped
Old 07-22-2013, 10:27 PM
Joemac5959's Avatar
That's a great idea. I used this idea on a sharp edge I cam across
Old 07-22-2013, 11:12 PM
JDEP162's Avatar
sure thing bud, protected mine several places with it.
Old 07-24-2013, 11:15 AM
eswizz's Avatar
I ran mine the same was you have yours JDEP162. Used adhesive backing clips that fit the nitrous line in it and the zip tie clips. It's all hidden and all out side of the car which is nice.
Quick Reply: Need help Running nitrous line
