What Nitrous kit for Cam Only ls1?
Old 03-26-2014, 09:03 PM
91ls1silverado's Avatar
Default What Nitrous kit for Cam Only ls1?
I swapped a ls1 with a cam in my 91 c1500 and i always wanted to go nitrous so i think its time i make a move...I did some research and they say a wet 150 is safe? Is that true? And should i get the 78mm plate? Nitrous outlet or Nitrous express? And what else would i need to get/do? Thanks
Truck has a rebuilt ls1 with a 227/235 cam, longtubes and cold air intake, 28lb injectors and 255 fuel pump.. 5 speed with 4.10s...i will only be using nitrous on the weekends when i go to the drags...any opinions welcome and thanks for looking!
Old 03-27-2014, 09:02 AM
brandon@nitrousoutlet's Avatar
150 is safe as long as you have your ducks in a row. You want to have the correct A/F ratio, be on the right plug, and have the right amount of timing in the motor. Would you want a braided hose system or one with hard lines?Here are a couple links for you to check out.
78mm Braided Hose kit:http://www.nitrousoutlet.com/nitrous...te-system.html
78mm Hard Line System: http://www.nitrousoutlet.com/nitrous...te-system.html (I know this says for F-body but if you're running an Ls1/6 intake it will fit fine.)
Accessory Packages: http://www.nitrousoutlet.com/nitrous...-packages.html
I would also recommend you a window switch: http://www.nitrousoutlet.com/electro...ow-switch.html
And a way to pull timing: http://www.nitrousoutlet.com/electro...ontroller.html
This is the spark plug you will want to run: http://www.nitrousoutlet.com/electro...ps-colder.html
All of these components make a safe and reliable system that will make all of the power you want. If you have any questions about any of these items please feel free to ask!
Old 03-27-2014, 10:08 AM
Thanks for the info Brandon! I was looking at the plate kit for the f body's and i like how its setup on the intake...i will give you guys a call within a month or so. Thanks!
Old 03-27-2014, 10:42 AM
Sounds good! You're welcome!
Old 03-27-2014, 10:18 PM
JDEP162's Avatar
cant go wrong with nitrous outlet, experts for sure. brandon hooked me and buddy up right too. follow his advice
Old 03-27-2014, 10:42 PM
high impact's Avatar
Another nod here toward nitrous outlet. Customer support and knowledge is fantastic.
Old 02-23-2015, 11:17 AM
Alright guys its been a while, but Im finally putting in my t56 next week and since i am going nitrous i was wondering what would be best to activate the nitrous... I want to push a button instead of having the switch on the pedal... Does anyone sell shift ***** with the button?
Old 02-23-2015, 11:22 AM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
We don't sell the shift *****, but we have plenty of buttons! Normally the company that makes your shifter is the one that would have something like that.
Thanks,
Garrett
Old 02-23-2015, 11:19 PM
SMEC-SS's Avatar
Love my NX kit!
Old 02-24-2015, 01:23 AM
SSmokin99's Avatar
Are the NX kits rated at the wheels?
Old 02-24-2015, 03:05 AM
HCI2000SS's Avatar
Yes they are
Old 02-24-2015, 08:33 AM
What he said! ^^
Thanks,
Garrett
Quick Reply: What Nitrous kit for Cam Only ls1?
