where to pull tach signal?
i pulled mine from the main coil pack harness on the passenger side, its a light green wire i believe. right near the middle of the connectors main plug before it splits to each cylinder. i got that right from instructions. i used no wires from the pcm. works perfect
I'm going to give that a shot, I just trouble shot all the wiring with Randy from leash electronics. Everything completes the circuit and solenoids click. It is supplying the signal to the window switch as well but the window switch either is bad or isn't getting a good tach signal.
