SBE cam and spray car goes 1.23 60' on radials with 4l60e.
Old 04-30-2014, 12:07 PM
TeEnAgE pHeNoM's Avatar
Default SBE cam and spray car goes 1.23 60' on radials with 4l60e.
I haven't posted an update of the car in a while. We got around to doing a little weight reduction as well as finishing the front suspension on the car. I'm not releasing any times until I get the car where I want it but I'm willing to share the new setup as well as 60'.
Changes made were:
Tick custom cam 232/250 .629/.623 113+5
Custom FTI triple disk converter
3.70 gears
275 radial pro
3200 raceweight
Still stock heads, intake, and throttle body. Nitrous outlet 78mm plate with a 93n/39f jet on c16 and 12* of spark. This was leaving off the footbrake.
The car went 1.231 60'! I only had two trips to the track with the car and managed a 1.29, 1.27, 1.25, 1.24, and 1.23 60'. Looking forwards to sharing the times with you guys soon.
Shout out to Martin Smallwood at Tick Performance for an awesome camshaft and Greg at FTI for an awesome converter!
Old 04-30-2014, 03:01 PM
87silverbullet's Avatar
That's getting it done son! I guess this was at the Hub?
Old 04-30-2014, 04:04 PM
9 Second Club/Nitrous Mod
shortdog's Avatar
Whoa, 1.2 60s.. Hell, i'm happy to hit 1.3s.. While most have upgraded to TH350 or TH400 on the big shot, he's getting it done on a 4l60E with a 300+ shot! Not sure how much more it'll take, but there is hope for us built 4l60E cars.
Old 04-30-2014, 09:03 PM
01 4.8's Avatar
Nice 60ft
Old 04-30-2014, 09:11 PM
Forgot to mention I was only leaving on 200 shot with .6 ramp time.
The car didn't even pick up a tenth on a 93 jet versus 78 jet. Was running the same fuel jet.
87bullet, this was at holly springs. Went 1.25 and 1.27 at atmore on less jet.
Old 04-30-2014, 10:31 PM
Omega Doom's Avatar
holy moly thats hookin' bro!!!!! i bet your ET was in the high 9's lets say around a 9.7-9.8s@ around 138-142ish mph
Old 04-30-2014, 11:29 PM
Killer5.3's Avatar
Car has already run 9.80's @3500+ lbs on .078 jet. Let's just say it is quite a bit quicker now and we have some changes being made that will make a BIG difference. Shortdog it is a Rossler Terminator 3 with every option Carl offers. Have over 200 passes on it and fluid still looks brand new when it is changed. It is by far the best 4L60E out there in our opinion. It still has all 4 gears. No tricks. It has a transbrake that we haven't even tried on the spray yet.
The following users liked this post:
pimpdulla (09-19-2020)
Old 05-01-2014, 07:02 AM
JRENIGAR's Avatar
Damn, I say damn son, now that getin it done right there.
Old 05-01-2014, 09:37 PM
Old School Heavy
speedtigger's Avatar
That is getting gone in a hurry. 275X's?
Old 05-01-2014, 09:38 PM
BSmiff's Avatar
I didnt even know Rossler made a 4L60e
Old 05-01-2014, 10:15 PM
They are the mickey thompson drag radial pros
Yes. It's his last priority and he usually can't get to them for 4-6 months. He sends people to rpm.
Old 05-03-2014, 04:30 PM
shortdog's Avatar
^Meant to ask, are you guys still pulling from the fuel rails with that much nitrous?
Old 05-03-2014, 04:56 PM
Killer5.3's Avatar
We have pulled .093 / .046 jet off the rail with no issues,but, we have a stand alone now.
Old 05-28-2014, 01:00 AM
greenvortec97's Avatar
Simply amazing. I'm struggling here at 10.46 130mph 1.4960ft on a 250 shot through an 80e. a little rich but I should of seen 9's a long time ago. Your car is running ***** to the wall man, props
Old 05-28-2014, 07:37 AM
You might need a better cam and are you hitting your car directly out of the hole? 1.49 doesn't seen like you are.
Old 05-28-2014, 09:15 AM
BSmiff's Avatar
Yea that 60 needs some work. Gonna need at least a 1.35-1.36 to get into the 9s with nitrous from what ive seen but its generally easier with a bottom 1.3x. I think carter had a 1.29 when he went 9.97.
Old 05-28-2014, 10:09 AM
I went 9.84 with a 1.44 60' at full weight with cam and 200 shot. It can be done. Car just has to make some steam.
Old 05-29-2014, 12:27 PM
spraying out of the hole
Old 05-29-2014, 01:27 PM
Old School Heavy
I went 10.04 at only 133 MPH with a 1.42 60' on an 81 jet at #3780. Now that I am down to #3680, I expect to be into the 9s next attempt with roughly the same 60'.
Old 05-29-2014, 01:41 PM
BSmiff's Avatar
Most def. And if the converter isnt right on the big end, its going to be a lot harder to get into the 9s for sure.
Quick Reply: SBE cam and spray car goes 1.23 60' on radials with 4l60e.
