head bolts
Old 05-31-2014, 11:37 AM
my406cid's Avatar
Default head bolts
Will factory head gasket and bolt hold up to a 200 dry shot on a lq9?
Old 05-31-2014, 11:40 AM
Burken01's Avatar
It should, most FI guys spit 600-700 hp through stock shortblocks!!
Old 05-31-2014, 04:38 PM
WE TODD DID's Avatar
The gasket will, but I'm not so sure on the bolts. Spray it and see what happens after a while.
Old 05-31-2014, 04:44 PM
my406cid's Avatar
What is the most that has been seen? I saw a 5.3 that went at the 900horse level for 4 years before it blew
Old 05-31-2014, 04:49 PM
my406cid's Avatar
Funny todd
Old 06-01-2014, 06:10 AM
I've never sprayed anything with the stock bolts. But I will tell you that the main bolts will stretch and loosen up if you spray them a bunch. I would assume that the head bolts will do the same, and end up causing you to burn a gasket.
Old 06-02-2014, 09:01 AM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
Yes that will be fine.
-Garrett
Old 06-11-2014, 07:05 PM
my406cid's Avatar
Thanks garret
Quick Reply: head bolts
