Kit not producing the power...I have a few questions
Old 07-19-2014, 05:43 PM
KHShapiro's Avatar
Default Kit not producing the power...I have a few questions
I have a modified NOS 05177 kit that I have been running in my car. When I bought the kit, I didn't have the instructions, but I was able install it with no real problems. I also did a progressive controller, so the power addition could be seamless.
I was shooting for 100 rwhp, so I tried a .052 jet. I didn't meet my goal so I drilled the jet to a .054. I gained 100 early in the rpm range, but netted only 75 rwhp at peak. I settled with that as I didn't want to be greedy.
Fast forward a year later, and I now want more.....
I stepped up to a .062 jet and honestly picked up nothing at all.
The bottle pressure has been kept at 900-1000 and was freshly filled when on the dyno. Also the inline filter is clear and the solenoids are functioning.
I was thinking that maybe I had found the limit of the -3an lines used on some parts of this kit, but I have read that -3an is .138, more than double the size of my .062 jet.
Today I downloaded the instructions for the kit I have, and find it only comes with jets to 100hp (not wheel hp I'm sure). I think this kit may be limited to only flow 100 hp.
Here is a diagram of how my kit is installed:
I have the solenoids installed exactly as the diagram shows. I believe that dual solenoids are a good idea when running a progressive controller as if one fails and sticks open, it's very unlikely the other one will. I use it as a safety measure.
I am beginning to believe that the solenoids together may be the problem. I have understood the a 16020 solenoid will flow 150hp wide open. I also figure that would be enough for at least 135ish rwhp.
So, does anyone have any experience running dual solenoids like this? Does the two of them combined create a flow issue? Could it actually be the -3an line?
Any help would be greatly appreciated.
Old 07-19-2014, 07:13 PM
streetlegalls1's Avatar
Some important details are left out ,like what vehicle,mods,and what injectors.What first comes to mind is injectors not able to deliver.Any time you run injectors over 85% duty cycle you're starting to work them, this is another case where a wide band becomes important
Old 07-19-2014, 08:29 PM
red fury's Avatar
I run that kit. The most I ever got out of it using the noids that come with the kit was 135 rwhp (cam only, 42# injectors, full exhaust M6 at that time).
Old 07-20-2014, 08:15 AM
87silverbullet's Avatar
Where is the rest of the diagram you are not showing? You also say that you tried a 100 hp jet which you say is a .052, that kit says it's a .032. You are using the wet jetting. Did you convert the kit?
Old 07-20-2014, 09:33 AM
KHShapiro's Avatar
It is a head cam car that is properly equipped to handle and deliver the power. The shortcoming is not in the combo on the car, I has to be in the kit. Duty cycle is around 65%.
I am only running as the diagram shows. It is somewhat concealed so I didnt want to try to hide the rest of it. I am running it dry.
I'm hope someone with experience in nitrous flow might speak up and point out the limitations.
Some time ago I ran a kit in another car with a single nozzle and made power like it was supposed to. The kit used the same solenoid, but did NOT use two of them.
Old 07-20-2014, 09:36 AM
KHShapiro's Avatar
The used with dual nozzles runs dual .032 jets to make 100 hp, not one like I'm running.
I used http://www.robietherobot.com/nitrousjetcalculator.htm
And various other sites and threads to calculate jet sizes for my power goal s
Old 07-20-2014, 03:49 PM
I think the second solenoid is a restriction in the line. The orifice in those solenoids Is .078. When you put 2 of them, even though they have a bigger orifice than the jet, it's still in the way. I say ditch them and put a single .118 solenoid in there and go from there. What are you using to provide more fuel?
Old 07-20-2014, 04:06 PM
KHShapiro's Avatar
It's a dry shot and we use an IAT manipulator to add fuel
Old 07-21-2014, 09:52 PM
KHShapiro's Avatar
Removing one of the solenoids gained APPX 40rwhp.
Old 07-22-2014, 07:42 PM
1slow96z's Avatar
Replace the noid, that kit uses 2 noids because they are prone to leaking under pressure... I would not run just one on its own
Quick Reply: Kit not producing the power...I have a few questions
