Yank Pt4000 Stall Ok to Spray?
I just had a lifter collapse & I wanna go with different route this time with my car, I will be switching cams from a torquer v3 to a Tick Polluter V2 Cam for now, I plan to buy 243s for a head & cam swap. Just checking to see if it's okay to spray with yank pt4000 stall on 100-150 shot wet?
Thanks!
I dont normally shift the transmission at the track nor the street since i have a big stall, I just let it roll out through the gears. I stall the car at 2000rpm without breaking the tires loose. Since Yank doesn't recommend for the pt4000 to be on spray its going to be all new to me so i wouldnt know just yet. what rpm would you probably consider?
