new to nitrous
new to nitrous
so i am sorry if i ask stupid questions.
i have a 2002 z06. has a nitrous outlet kit installed(75 hp).
my tuner says i can't go to a 100 shot without running bigger injectors. that correct? would i need a bigger fuel pump? is a 100 hp shot pretty safe to run? whats the recommended rpm window for the nitrous? and the timing retard?
I know lot of the dry kits sometimes need more injector as hp goes up. the wet kit supplies its own fuel in a sense. I have sprayed over 200 with stock injectors. I'm sure others will chime in. I also have the Nitrous Outlet plate 2 stage.
Ls1tech & Truck Sponsor
If it is a wet system you don't need bigger injectors, that only applies to dry systems. The fuel for a wet system is provided through the fuel solenoid, not the injectors. You can run 100 shot on the factory fuel system and pump, with no issues, being that its pretty close to stock still.
Best of luck, let me know if you have anymore tech related questions.
Thanks,
Garrett
Thanks,
Garrett
