June Nitrous Specials From Nitro Daves!!
THIS SPECIAL WILL BE GOOD UNTILL THE END OF JUNE.
KIT#1
1.OUR HALO DRY KIT,comes with our halo spray bar,10lb bottle(black or White) fuel pressure safety switch,nitrous pressure gauge,NHRA blow off valve,blow down tube.Regular hard ware such as microswitch, lines, wiring, hardware ETC.
2.860 Performance heated bottle brackets.(best described as a hot plate with bottle brackets)
3.NX purge kit
4.MSD window switch with 3,000 and 6,000 pills
5.8-NGK TR6 spark plugs
6.860 Hex To Wing Nut
All this for 835.00 shiped in the US
KIT#2
1.NX Maff Kit-20920-10
Comes with 10lb bottle,Ice man lifetime warranty solenoids,TPS switch,Mass Air ends,bottle brackets,lines,hardware,etc
2.GENX-2 upgrade-Comes with automatic bottle heater,purge,fuel pressure safety switch,NHRA blow off valve,blow down tube,nitrous pressure gauge,wiring and fittings.
3.MSD window switch with 3000 and 6000 pills
4.8-NGK TR6 spark plugs
5.860 Hex To Wing Nut.
All this for 1310.00 Shiped in the US.
KIT#3
PIMP YOUR KIT
1.NX 2 1/16 piller mounted electric nitrous pressure gauge.Comes with harness and has white face.
2.860 V twin purge
3.860 Hex To Wing Nut
275.00 Shipped in the US.
Call in your order at 1-866-648-7637
KIT#1
3.NX purge kit
KIT#2
KIT#3
PIMP YOUR KIT
2.860 V twin purge
Originally Posted by Nitro Dave's Performance
We no longer can offer installs.
There are several dealers That I could send you to if you would like to give us a call.
Dave
Dave
Kyle was our install tech.He is currently out of school doing some work in Corpus christy.People like Kyle are hard to find.I am a very picky when it comes to people doing certain work for me.Kyle had the installs down to making it look like a work of art.Anyone can bolt on a system.All of Kyles connections was salderd,he would build a complete harness for the car.Everything was ran in loom.I knew that I did not have to double check his work.He is a pro.Unfortintly Kyle has left the speed world to go to work in the communications world.At this time I just dont have time to do the installs myself or train someone to replace him.We may start back up in the future.However I have been looking at some other peoples work to figure out where I may be able to send people.I recently seen some pics of an install on a vette here on the board done by Icon Motorsports.Now all I seen was the hard line job But it looked pretty good.So you may give Mike and Nick a call for the install.Im sorry for the incovience.
But we can deffintly help you out on the kit.
Dave
Dave
Dave
Dave
Thanks,
Quickin
Dave,
How much for just this, plus 2 solenoids instead of one:
3.NX purge kit
6. 860 Hex To Wing Nut Whats this for?
3.NX purge kit
I bought a pair of 860 (that's the brand name) Wing Nuts from Dave a couple weeks ago.
They are a heavy plastic wing nut that slides over the -AN tube fitting. No tools required. Makes it easy to connect/disconnect the lines without tools.
I've attached a picture. They seem pretty cool.
-Andrew
-Andrew
