From 11.51@117 to 10.26@131 on a 150shot
Wonder if this is an average gain for a 150shot? Maybe more in it? I pulled 7 degrees from my n/a timing of 28 but didn't check the plugs I think I can put one back in it I posted on drag racing results but only got one reply
I Went to the 1/4 mile track this Friday I was hoping for a better time and mph n/a but it was hot as hell out so that mite be part of it
Setup consist of
98 Ss ttop a4 front sway bar and a/c delete are the only weight reduction not sure what it weighs with me 220lbs I guess 3500
It's a aluminum 6.0 with forged pistons and rods stock crank
Patriot 5.3 heads cr 11.2:1
Lsr 231/239 cam
Ls6 intake
Open tsp y pipe for exhaust
Stock 10bolt 3.73s
Performabuilt 4l60
Fti3800 stall shifts at about 6200
Racetronix kit
Nos plate with 150 shot 65n 38f jets
3 point subframe connectors
Bmr torque arm
Viking da shocks front and back 300lbs springs
Pro stars with 275/50/15 Mickey Thompson drag radials at 14psi
First pass spun bad n/a
Rt .031
60ft 2.2
1/8 8.8 90mph
1/4 13.1@116
Second pass n/a
Rt .118
60ft 1.63
1/8 7.32@93.4
1/4 11.51@117.26
Third and last pass turned on the juice bottle pressure about 950
Rt .424
60ft 1.44
1/8 6.52@105
1/4 10.26@131
Temps that night were in the 91-92 degrees
Setup consist of
Lsr 231/239 cam
Ls6 intake
Stock 10bolt 3.73s
Performabuilt 4l60
Racetronix kit
Bmr torque arm
Rt .031
60ft 2.2
1/8 8.8 90mph
1/4 13.1@116
Second pass n/a
Rt .118
60ft 1.63
1/8 7.32@93.4
1/4 11.51@117.26
Rt .424
60ft 1.44
1/8 6.52@105
1/4 10.26@131
http://www.nitrousoutlet.com/efi-nit...onversion.html
I'm pretty sure that plate taps out at 200hp. One thing to also consider, if you are looking to run over 175 hp, you will want a 6an main feed line and a 4an to 3an "race" hose from the solenoid to the plate. Check out our plate as it will do exactly what you are looking for, AND it's 10% off right now!
Ls1tech & Truck Sponsor
-Chris
That looks like its working out for you. I have a similar setup and have not gone to the track yet but I am spraying a 150 shot when I hit the track next and will let you know what my results are. I'd say in a couple weeks I'll have an answer for you. My car is a manual too though, but similar
I ran the same plate. From a 67n jet to a 83n jet I only picked up 1 mph. I've upgraded to a nitrous outlet plate since then. But I'm taking baby steps again before I throw the 83 jet in this plate. With the nitrous outlet plate I did go .1 faster on same hp shot. When I ran the nos plate I had a couple cylinders running pretty fat compared to others. The nitrous outlet plate seems to distribute a million times better. Plugs are all pretty damn close to each other now. Just keep that in mind when running the nos plate.
Yea I'm gonna end up buying a new plate and upgrade the noid to plate line I hoping to see 9.90s with the car on a 200 shot but I don't know if the 10 bolt will hold that big of a hit
Anybody know what kinda power im putting down by my mph? Looks like most head cam cars trap in the 120s na mine is only 117 na
Work on ur 60ft and ur in the 9s. Here is what my cam only nitrous car did on both a 67n jet and a 83n jet with nos plate that u have...
